HDR & B&W Anyone?
HDR & B&W Anyone?
2008-09-09 by ilford100
So far I have managed to ignore HDR imaging, but curiosity has got the best of me.  I was
wonder1ing if anyone has used HDR compositing techniques, then tone mapped back to grey
scale.  More importantly, how did the image(s) look?  If you have such an animal, can you
post a link to it?
Thanks
Re: HDR & B&W Anyone?
2008-09-09 by the_des_bois
I've found this point of vue interesting:
http://www.apogeephoto.com/june2007/jaustin62007.shtml
Denis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ilford100"
mapped back to grey
> post a link to it?
> Thanks
2008-09-10 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ilford100" <robertrowe2@...>
grey
> post a link to it?
Hello Robert, I've played with it a bit both through color to b&w conversions and infrared to
b&w conversions.  I've gotten some very, very, rich midtones using both PSCS3's HDR
conversion and Photomatix's tone mapping.  It's probably lack of experience with both but I
also get very posterized highlights and shadows with both.  I think there is a lot of potential
there for very rich tones, sort of like pulling Tech Pan, but lots and lots of bugs to work out.
It's not very high on my list right now but come this winter with some free time I think it's
worth more exploration.
All you can do is give it a try;)
grey
> post a link to it?
2008-10-09 by tynmansystems
A reference was given earlier in the thread to an article on the use
of HDR techniques for B&W images. It was full of remarks like "Subtle
changes from dark to light tones can act as metaphors for the passage
of time." Not sure what the author was smoking, but each to their own...
I haven't used the Photomatix product discussed in that article, but
it sounds interesting. Photoshop has the "Merge to HDR" utility (under
File>Automate menu), but I haven't managed to get that to work.
I have used Photoshop's "Load Files Into Stack" utility to merge
multiple, exposure-bracketed images to process HDR scenes, with some
success. If you're interested, the workflow follows. I certainly
didn't invent this -- it is lifted from some article I found somewhere
on the web and edited somewhat over time as I`ve used it
Step 1
Load the three images into Photoshop (applies to CS3), using
File>Scripts>Load Files Into Stack menu item.
In the Load Layers window, browse for and select the three images.
Check the "Attempt to Automatically Align Source Images" checkbox.
Step 2
You will end up with a document with three layers, one with the
over-exposed image, one with the normal-exposed image and one with the
under-exposed image. Use the mouse to drag the layers so that the
normal-exposure is the bottom layer, the under-exposure is in the
middle and the over-exposure is at the top.
Step 3
Select the over-exposure layer and add a layer mask by selecting the
Layer> Add Layer Mask menu and selecting Reveal All.
Step 4
Select the Image >Apply Image menu item. In the Apply Image window,
check Invert and click OK.
Step 5
Select the under-exposure layer and add a layer mask by selecting the
Step 6
Select the Image>Apply Image menu. In the Apply Image window,
*uncheck* Invert, then click OK.
Step 7
Adjust the opacity setting on the over-exposure and under-exposure
layers to taste. You typically adjust the over-exposure layer opacity
to dial in shadow detail, and adjust the under-exposure layer opacity
to dial in highlight detail.
If the captures are in color, converting to B&W is the same as for any
other color image. I use the Layer>New Adjustment Layer>Black&White
menu item.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "the_des_bois"
> Denis
> mapped back to grey
> > post a link to it?
> > Thanks
Re: [Digital BW] Re: HDR & B&W Anyone?
2008-10-09 by Dana H. Myers
I've experimented with HDR using the freeware qtpfsgui utility
and multiple scans from my Nikon LS9000, adjusting the analog
gain for each scan.  The registration of the images is apparently
excellent; I'm not seeing a sharpness problem.
The result are interesting, particularly when I start with
real "problem" negs.  It certainly speaks to the latitude of
B&W negative film that we've been discussing already.
Dana
2008-10-09 by steveabrink
Dynamic Photo is an HDR package thats similar in capablity to
Photomatix and is about half the cost. Its simple and very quick to
use and has tonemapping capabilities (like photograpic and auto-
adaptive modes) that extends dynamic range w/o the exaggerated look.
For some scenes it can work well.
SteveB
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tynmansystems"
like "Subtle
passage
own...
(under
somewhere
> Step 1
> Step 2
> Step 3
> Step 4
> Step 5
> Step 6
> Step 7
opacity
opacity
any
> menu item.
> > Denis
got
tone
> > mapped back to grey
have
> > > post a link to it?
> > > Thanks
2008-10-10 by Tyler Boley
HDR has been useful for difficult images from time to time, used in ways for which it was
not intended. THis relates to the zone system/film/scanning compression thread as well.
One thing film can do, even when a great deal of minus development is used to control
excessive scene range, is remain (for the sake of this discussion) virtually continuous tone.
In other words, despite the dramatic compression, there is still tonal distinction, no
outright posterization. So with a hi bit scan, those locally compressed tones can be pulled
apart nicely.
But it can be difficult. A recent image made down in a forest ravine looking out into sunlit
areas was very compacted via developement, and the density range scanned easily. But
despite a lot of messing around it was hard to get pleasing local contrast and retain the
range, with such image complexity.
HDR does seem to deal with this successfully sometimes, so I fooled it. I've never been
successful with PS HDR, so this was with Photomatix. I simply made different file versions
from that scan, increasing contrast and changing brightness similar to what a bracket
might have looked like letting extremes go, then combined them with Photomatix. If I
recall I had to put in some fake exposure data. Obvioulsy registration is a non-issue.
It only got part way there, I wound up working it as a new scan with masked adjustment
layers etc., and layered back in the original scan in areas, but it gave a good starting point
I doubt I could achieved manually. One exposure, one scan.
The point is, when all else fails, break the rules... use tools for what they seem to be good
at, often not what they were intended for...
Tyler
was
grey
you
> post a link to it?
> Thanks
2008-10-10 by donbga
Tyler,
> I've never been
to what a bracket
Photomatix. If I
I've used this same technique with 4x5 Velvia when the scale of the
image couldn't be handled by my cheap Epson 2450. Making two scans
with different gamma I was able to composite the two scans with
Photomatix and get the full range of the tranparency.
So yeah the technique works.
Don Bryant
2008-10-10 by pr_roark
I can see that these digital tools can simplify some of what we've done
manually, including dodging and burning.  (I anticipate initial
overused -- which I've certainly been guilty of with new tools or
toys.)
The Potomatix website is at
http://www.hdrsoft.com/
I still do even dslr dual-frame images manually.  (I was not happy with
the PS CS2 version of HDR.)
The following is typical of my manual versions of HDR:
http://www.paulroark.com/Foxs_&_Cirque.html  It makes an interesting
comparison to the Photomatix sample on its web page, above.
2008-10-10 by Roger
I really dislike most of the examples on their webpage but swear by
photomatix.  I use it to combine slide scans and avoid noise and to do
the same with high contrast digital scenes.  I do bit use its HDR
feature but rather the combine images one which lets you extend the
dynamic range as with using layers and masks.
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> toys.)
> Paul
> www.PaulRoark.com
2008-10-12 by Jules
I read that article the other from the link on DPR. Looking at the first two images that
they show I prefer the single exposure image any day. The HDR one might contain more
shadow and highlight detail but it is as boring as hell and flat as a pancake.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "the_des_bois" <thedesbois@...>
> Denis
> mapped back to grey
> > post a link to it?
> > Thanks
2008-10-12 by Jules
Re your last paragraph, do you mean Hue/Saturation when you say Black and White menu (as
this does not exist). This step is crutial to a great b&w image and not as simple as the one
step that your refer to it as.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tynmansystems"
> menu item.
