R-800 Nasty cyan clog
2008-10-07 by scott_now_coming
Any ideas on how to un-clog a nasty cyan channel on an R-800? I ran cleaning carts and let the printer set overnight. I'm in the process of a puddle clean with a mixture of 90% distilled water and 10% amonia. I plan to leave it sit overnight, too. Isn't there a way to manually flush the head(s)? Paul......?
2008-10-07 by Roger
I'd keep the cleaning cart(s) in for a few days and run a few MIS R800 purge test prints on plain paper each day. It should clear soon. This worked for me when I unplugged my R220 with carts not in the park position and forgot about it for a month. Roger In DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming" <scott_now_coming@...> wrote:
> > Any ideas on how to un-clog a nasty cyan channel on an R-800? > > I ran cleaning carts and let the printer set overnight. I'm in the > process of a puddle clean with a mixture of 90% distilled water and 10% > amonia. I plan to leave it sit overnight, too. > > Isn't there a way to manually flush the head(s)? > > Paul......? >
2008-10-07 by pr_roark
> Any ideas on how to un-clog a nasty cyan channel on an R-800? > > I ran cleaning carts and let the printer set overnight. I'm in the > process of a puddle clean with a mixture of 90% distilled water and 10% > amonia. I plan to leave it sit overnight, too. > > Isn't there a way to manually flush the head(s)? > If the cleaning cart and Windex or ammonia on the pad over night (or for days) does not work, try a syringe with a tube on it, Windex or an ammonia mix in it, and direct injection into the head via the normal inlet. The last serious clog I had was on my 7500 where I could not use a cleaning cart. Not a single jet was firing. I pulled the damper (K position) and injected Windex -- with some rather energetic pusshing and pulling on the syringe. I also put a dilute mix in the damper and put the system back together. The next morning after one cleaning cycle the nozzles were perfect. No guarantees, but the Epson authorized repair person in the area showed me the same trick. He squired cleaning fluid through heads he'd removed from printers to clean them out. For what it's worth ... Paul www.PaulRoark.com
2008-10-07 by Charles Becker
Create a solid block of cyan (as wide as the papaer your using and about 3 inches in height)�as an image then send to the printer and crank up the cyan in the driver setting to try and flush out. It has worked for me in the past with tough clogs. � Best, Charles --- On Tue, 10/7/08, scott_now_coming <scott_now_coming@...> wrote:
Subject: [Digital BW] R-800 Nasty cyan clog
Date: Tuesday, October 7, 2008, 8:11 AM
Paul......?
[Non-text portions of this message have been removed]2008-10-07 by scott_now_coming
Thanks, but I'm at a "last resort" here. I've printed lieterly TONS of purge patterns and solid blocks of cyan pages. I've run cleaning carts for a couple of weeks. This is MAJOR. I'm thinking the printing head may be gone. I'm getting NO ink through the head. Nothing. Nada. Zip. Zilch.... you get the point. :~) Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Charles Becker <gypyjunior@...> wrote: > > Create a solid block of cyan (as wide as the papaer your using and about 3 inches in height) as an image then send to the printer and crank up the cyan in the driver setting to try and flush out. It has worked for me in the past with tough clogs. > > Best, Charles > > --- On Tue, 10/7/08, scott_now_coming <scott_now_coming@...> wrote: > > From: scott_now_coming <scott_now_coming@...> > Subject: [Digital BW] R-800 Nasty cyan clog > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Date: Tuesday, October 7, 2008, 8:11 AM > > > > > > > Any ideas on how to un-clog a nasty cyan channel on an R-800? > > I ran cleaning carts and let the printer set overnight. I'm in the > process of a puddle clean with a mixture of 90% distilled water and 10%
> amonia. I plan to leave it sit overnight, too. > > Isn't there a way to manually flush the head(s)? > > Paul......? > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
2008-10-10 by Pacific New Media
I am planing to mix multiple shades of b&w inks from Photo Black (PK)
for printing on glossy paper. I have a few questions:
Is photo black a result of mixed color inks? What is a good ink base
formula for mixing with photo black - I wish there is a version of
colorless Windex :).
What is a good ratio of ink base vs PK ink? For example,
3 shades: 100% PK, 50% PK, 12.5% PK
4 shades: 100% PK, 50% PK, 25% PK, 12.5% PK
6 shades: 100%PK, 75% PK, 50% PK, 25% PK, 12.5% PK, 6.25% PK
8 shades: Any benefits for that many shades?
- Philip2008-10-10 by pr_roark
Philip, > I am planing to mix multiple shades of b&w inks from Photo Black (PK) > for printing on glossy paper. I have a few questions: > > Is photo black a result of mixed color inks? MIS PK that is 100% carbon pigment in most of it's sets. Those that are blended with color pigments generally are called "PKN" or the like. > What is a good ink base > formula for mixing with photo black - I wish there is a version of > colorless Windex :). MIS Glop is the base I recommend for their glossy inks. > > What is a good ratio of ink base vs PK ink? The standard dilution for PK to LK, and LK to LLK is 30% darker ink, 70% clear base. I've used ratios of from 1:1 to 1:3 with the Epson driver crossovers and had them work fine. > For example, > 3 shades: 100% PK, 50% PK, 12.5% PK > 4 shades: 100% PK, 50% PK, 25% PK, 12.5% PK > 6 shades: 100%PK, 75% PK, 50% PK, 25% PK, 12.5% PK, 6.25% PK > 8 shades: Any benefits for that many shades? The inksets with many shades often use one that is close to 2% black, 98% clear base. You'd be surprised at how dilute you can go. You're examples are rather dark in comparison. On the other hand, the standard UT-C (darkest dilute carbon ink) is denser than the 30% PK because it was based on the higher load MK, not the PK, since the early focus was on matte papers. Good luck with the mixing. Paul www.PaulRoark.com
Thanks Paul. Actually I was reading your writing about Carbon-6 just a few minutes ago and starting realize my example of mix might be too dark. So the better mixes can be: 3 shades: 100% PK, 33% PK 10% PK 4 shades: 100% PK, 33% PK, 10% PK, 3.3% PK 6 shades: 100% PK, 33% PK, 16.7% PK, 8.3% PK, 4.2% PK, 2.1%PK Thanks, - Philip pr_roark wrote:
> > Philip, > > > I am planing to mix multiple shades of b&w inks from Photo Black (PK) > > for printing on glossy paper. I have a few questions: > > > > Is photo black a result of mixed color inks? > > MIS PK that is 100% carbon pigment in most of it's sets. Those that > are blended with color pigments generally are called "PKN" or the like. > > > What is a good ink base > > formula for mixing with photo black - I wish there is a version of > > colorless Windex :). > > MIS Glop is the base I recommend for their glossy inks. > > > > > What is a good ratio of ink base vs PK ink? > > The standard dilution for PK to LK, and LK to LLK is 30% darker ink, > 70% clear base. I've used ratios of from 1:1 to 1:3 with the Epson > driver crossovers and had them work fine. > > > For example, > > 3 shades: 100% PK, 50% PK, 12.5% PK > > 4 shades: 100% PK, 50% PK, 25% PK, 12.5% PK > > 6 shades: 100%PK, 75% PK, 50% PK, 25% PK, 12.5% PK, 6.25% PK > > 8 shades: Any benefits for that many shades? > > The inksets with many shades often use one that is close to 2% black, > 98% clear base. You'd be surprised at how dilute you can go. You're > examples are rather dark in comparison. On the other hand, the > standard UT-C (darkest dilute carbon ink) is denser than the 30% PK > because it was based on the higher load MK, not the PK, since the early > focus was on matte papers. > > Good luck with the mixing. > > Paul > www.PaulRoark.com > >
Philip, > I was reading your writing about Carbon-6 just a > few minutes ago and starting realize my example of mix > might be too dark. > > So the better mixes can be: > 3 shades: 100% PK, 33% PK 10% PK > 4 shades: 100% PK, 33% PK, 10% PK, 3.3% PK > 6 shades: 100% PK, 33% PK, 16.7% PK, 8.3% PK, 4.2% PK, 2.1%PK > In the C6 mix I used 33% MK for the darkest mix. This was selected due to the ease of mixing. It would allow those who did not have scales more easily mix the inkset. Since it was close to the usual darkest "traditional" B&W dilution of 30% MK, I figured it's work well, and it does in older printers. However, note that I've reverted to a 30% Eboni mix for the k3 printers. It turns out the 33% is too dark for k3 printers and some papers. It results in inadequate separation or even posterization in the deep shadows when the Epson driver is used. It appears this is caused by the k3 gray substitution algorithm. The 33% mix works fine in the k2 printers. This may not affect you at all with PK and if you're not using the Epson driver, but it illustrates something important. While 30% is the usual dilution of PK to make LK, etc., and 30% MK is the "traditional" B&W darkest mix, this 30% mix is a considerably higher load than LK. The LK density can be mixed from MK if about 18% MK is used. In terms of print density, however, to put the LK (18% MK) in perspective, recall that the dilution-ratio to print-density curve is very non-linear as the pigment load gets high. Actually, this curve is very non-linear at both ends. That explains how a 2% dilution can cover about 25% of the print range. Paul www.PaulRoark.com
2008-10-12 by Pacific New Media
Thanks Paul. I will start to set up the ink and printer using your suggestions. I find there is still a need for B&W inkjet printing onto a more glossy paper than pure matte surface - satin or semi-glossy. Sometimes I feel we may be should revisit dye-based ink for b&w printing. Thanks, Philip pr_roark wrote:
> > Philip, > > > I was reading your writing about Carbon-6 just a > > few minutes ago and starting realize my example of mix > > might be too dark. > > > > So the better mixes can be: > > 3 shades: 100% PK, 33% PK 10% PK > > 4 shades: 100% PK, 33% PK, 10% PK, 3.3% PK > > 6 shades: 100% PK, 33% PK, 16.7% PK, 8.3% PK, 4.2% PK, 2.1%PK > > > > In the C6 mix I used 33% MK for the darkest mix. This was selected due > to the ease of mixing. It would allow those who did not have scales > more easily mix the inkset. Since it was close to the usual > darkest "traditional" B&W dilution of 30% MK, I figured it's work well, > and it does in older printers. However, note that I've reverted to a > 30% Eboni mix for the k3 printers. It turns out the 33% is too dark > for k3 printers and some papers. It results in inadequate separation > or even posterization in the deep shadows when the Epson driver is > used. It appears this is caused by the k3 gray substitution > algorithm. The 33% mix works fine in the k2 printers. > > This may not affect you at all with PK and if you're not using the > Epson driver, but it illustrates something important. > > While 30% is the usual dilution of PK to make LK, etc., and 30% MK is > the "traditional" B&W darkest mix, this 30% mix is a considerably > higher load than LK. The LK density can be mixed from MK if about 18% > MK is used. > > In terms of print density, however, to put the LK (18% MK) in > perspective, recall that the dilution-ratio to print-density curve is > very non-linear as the pigment load gets high. Actually, this curve is > very non-linear at both ends. That explains how a 2% dilution can > cover about 25% of the print range. > > Paul > www.PaulRoark.com > >
2008-10-12 by Michael King
You can print with the matte inks onto satin or semi-gloss no problem. You just need to finish the print with either a glop over print or spray varnish, to get rid of the bornzing. Probably best to give it several light coats of glop or varnish. I've experimented with this on IGFS with Cone inks and it works great. Mike 2008/10/12 Pacific New Media <panmedia@...>:
> Thanks Paul. I will start to set up the ink and printer using your > suggestions. > > I find there is still a need for B&W inkjet printing onto a more glossy > paper than pure matte surface - satin or semi-glossy. Sometimes I feel > we may be should revisit dye-based ink for b&w printing. > > Thanks, > Philip > > pr_roark wrote: >> >> Philip, >> >> > I was reading your writing about Carbon-6 just a >> > few minutes ago and starting realize my example of mix >> > might be too dark. >> > >> > So the better mixes can be: >> > 3 shades: 100% PK, 33% PK 10% PK >> > 4 shades: 100% PK, 33% PK, 10% PK, 3.3% PK >> > 6 shades: 100% PK, 33% PK, 16.7% PK, 8.3% PK, 4.2% PK, 2.1%PK >> > >> >> In the C6 mix I used 33% MK for the darkest mix. This was selected due >> to the ease of mixing. It would allow those who did not have scales >> more easily mix the inkset. Since it was close to the usual >> darkest "traditional" B&W dilution of 30% MK, I figured it's work well, >> and it does in older printers. However, note that I've reverted to a >> 30% Eboni mix for the k3 printers. It turns out the 33% is too dark >> for k3 printers and some papers. It results in inadequate separation >> or even posterization in the deep shadows when the Epson driver is >> used. It appears this is caused by the k3 gray substitution >> algorithm. The 33% mix works fine in the k2 printers. >> >> This may not affect you at all with PK and if you're not using the >> Epson driver, but it illustrates something important. >> >> While 30% is the usual dilution of PK to make LK, etc., and 30% MK is >> the "traditional" B&W darkest mix, this 30% mix is a considerably >> higher load than LK. The LK density can be mixed from MK if about 18% >> MK is used. >> >> In terms of print density, however, to put the LK (18% MK) in >> perspective, recall that the dilution-ratio to print-density curve is >> very non-linear as the pigment load gets high. Actually, this curve is >> very non-linear at both ends. That explains how a 2% dilution can >> cover about 25% of the print range. >> >> Paul >> www.PaulRoark.com >> >> > > > ------------------------------------ > > Please visit the Group Homepage to check the Files, and other resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep them short. > - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. > - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. > - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. > Yahoo! Groups Links > > > >
2008-10-13 by Barrett Benton
Philip writ: > I find there is still a need for B&W inkjet printing onto a more > glossy > paper than pure matte surface - satin or semi-glossy. Sometimes I feel > we may be should revisit dye-based ink for b&w printing. This is the reason why I've stuck with HP's 8750 for both my color and b/w printing: archival dye inks (which do need to be used with HP's papers for optimum stability, though I suspect other "swellable" papers might work nearly as well). I simply got tired of dealing with the standard-issue artifacts of most pigment-ink setups (third-party or factory "turnkey" systems), and wanted great results for black-and-white *and* color. This printer (which HP just recently discontinued) has done it for me. Mind you, Epson, HP and Canon are still toying with dye-based formulas for just this reason. (Traditionally, pigment inks provide the best image stability, but wreak havoc in terms of visual artifacts�metamerism, bronzing, and gloss differential�particularly with glossy or semi-gloss/satin papers, right up to this day, although the best pigs have minimized this to a degree). I have to say that if it hadn't been for the efforts of Paul Roark and company, we'd be in *far* worse shape than we're in now. That being said, I don't think "dye is dead" by a long shot. (It had better not be: my current solo show in Red Hook, Brooklyn, is riding on this. :-) - Barrett [Non-text portions of this message have been removed]
2008-10-16 by Pacific New Media
Paul, Can the ink base suggested in your carbon-6 document be used to dilute MIS dye based black ink ? Or in general, the ink base for pigment ink and dye ink, do they have different requirements? Thanks - Philip > >
2008-10-16 by pr_roark
I assume the ink bases are different for pigment and dye inks. I've never looked into the composition of the dye bases. Paul www.PaulRoark.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Pacific New Media <panmedia@...> wrote: > > Paul, > > Can the ink base suggested in your carbon-6 document be used to dilute
> MIS dye based black ink ? > > Or in general, the ink base for pigment ink and dye ink, do they have > different requirements? > > Thanks > - Philip > > > > >
