Eboni-6 with the Epson 2100
2008-10-15 by arthurkrick
Eboni-6 with the Epson 2100.
Has anyone had any experience of using this combination ? Will it work ?
My initial intention was to use the Eboni-6 in my old 1290 which had been used with Piezo
but this now seems to be irretrievably
blocked.
Looked at getting a new 1400 for dedicated B&W with Eboni but am put off by adverse
comments that have been made on the flakey paper transport
Views and advice greatly appreciated
Re: Eboni-6 with the Epson 2100
2008-10-15 by pr_roark
> Will it work ?
I have Carbon-6 in my 2200, and it works fine.  It's about the same
as Eboni-6.  One caviate is that I specified LK = M in the mix.  This
is fine with the Epson driver, which is what I usually use (with a
QTR ICC), but the QTR rip probably cannot partition a set of inks
where there are 2 with the same density.  So, I've experimented with
other density arrangements.
However, what I've found is that with k2 and k3 printers -- if not
most when using the QTR rip -- they are best set up with 2 different
profiles that use sub-sets of the inks.  The second lightest (Eb6-LM)
ink is light enough to be a starting ink in the second profile, but
you can use some of the same inks in both.  Both profiles will have K
as the final.  So, one profile could use, for example, Y, LC, LK, C,
K, and the second Y, LM, M, K.  The idea is to have different
crossovers and multiple inks printing at the same time.  When
printing, use the sliders in QTR to use both profiles.  In effect, I
don't recommend what I'd call a single, serial partitioning.  Rather,
2 parallel partitions in 2 profiles makes for a smoother print.
My 1400 does a good -- actually superior -- job feeding paper up to
and including H. Photo Rag 308.  With 325 gsm Premier Art it's
problematic.  At least the 1400 I have does have a different pre-feed
system -- it just shots the paper through the printer.  So, pre-
feeding paper just does not work.
2008-10-16 by arthurkrick
Paul,
thank you for your full explanation in response to my question re 2100/2200 &
Eboni-6.
In view of what you say, maybe I should discount the reservations I've acquired about
poterntial paper feed problems on the 1400 and go that route with the full Eboni-6 inkset.
 I'm looking for it to be a dedicated B&W printer and certainly, the smoothness of tone that
you have demonstrated with this set up would be my ideal.
Arthur
2008-10-16 by pr_roark
For my current tastes, a competitively priced, 1.5 pl hextone printer
like the 1400 seems like a good deal for 100% carbon pigment
printing.
With Eboni-6, these 1.5 pl printers are about one Lab B unit warmer
than the older 3+ pl units.
On the other hand, the ability to print reasonably smooth 100% Eboni,
however, allows much more neutral printing, bringing in the entire
range of the 3-MK 1800 approach.  I particularl like the un-
brightened papers with Eboni black only.  See
http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf
Being able to mix the characteristics of the dilute Eboni-6 approach -
- http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf -- with the
3-MK/BO (via QTR) workflow makes for a more flexible inkset.  The
tonal range expands, the paper range expands, and we get control over
the random "grain" or noise level, which can be useful.
____
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "arthurkrick"
> Paul,
> question re 2100/2200 & Eboni-6.
> Arthur
