17 stops of Linear latitude
Re: 17 stops of Linear latitude
2008-10-07 by pr_roark
> I do not doubt the 17 stops.
> I do believe the results would not be linear.
That's a big reason I take multiple shots with roll film (or digital).
Even though my film and scanning can get some information from, for
example, extreme highlights, the image information is usually
significantly better from the portions of the curve that better
separation and lower noise.
(Is there a digital equivalent to the 1 - 2% pre-flashing of slide film
we used to occasionally do to increase the deep shadow sensitity?)
RE: [Digital BW] 17 stops of Linear latitude
2008-10-08 by Steve Gledhill
Fred,
I'm sure that's correct - though I don't try to measure it.  It does result
in a challenge when working with such a file to represent my desired
contrasts in each different area of the final print.  And the compression
referred to earlier requires some areas of the image to be stretched more to
obtain that desired contrast.  So, lots of local work all over an image.
But then, that's what I enjoy and that's what 16 bit Photoshop is for!
Steve Gledhill
www.virtuallygrey.co.uk <http://www.virtuallygrey.co.uk/>
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Fred
Sent: 07 October 2008 22:49
Subject: [Digital BW] 17 stops of Linear latitude
I do not doubt the 17 stops. I do believe the results would not be linear.
2008-10-08 by Fred
 Paul, that is called 'bumping'. Very useful when trying to open shadow/deep areas on
transparency. You could 'color' the bump with filtration to somewhat change the deeper hues.
Have you ever tried 'laintensification'? It has been many years but I do remember that
working very well with good linear results. It was a post capture pre-process intensifier.
Fred
Re: [Digital BW] Re: 17 stops of Linear latitude
2008-10-08 by Roger
Fred, that's not digital, is it?
I've thought about this and I don't think there is an equivalent in the
digital world. If bumping is digital, is it only for scans, e.g., do you
do multiple scans and "add" them?
Roger
> remember that
> Fred
2008-10-08 by Fred
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Roger <user1@...> wrote:
 Nope. That is in the chemical world. Digitally, If I have a difficult scene range-wise I do what
most others do, bracket or raw process a range.
Again, if its a difficult one, yes I will scan for hilite and/or shadow.
There is a method that I once used before photoshop Shadow/Highlight was around. I don't
remember it well. It may have been some Dan Margulis method.
Fred
Re: [Digital BW] 17 stops of Linear latitude
2008-10-08 by Steve Kale
Those interested in dynamic range and A/D conversion may be interested
in the material here:
http://www.normankoren.com/digital_tonality.html
Personally, I think that in order to preserve the maximum amount of
information through the analog to digital conversion (whether that is
done at the scanner from high bandwidth film or from the high
bandwidth scene direct to digital) one will only retain maximum
information with multiple exposures.  After all, a scanner merely
projects light towards film and measures the output.  Not that much
different from direct digital capture.  If the camera/scanner has a
high bit depth it can capture more levels within the range and allow
more room for maneouvre within Photoshop before degradation occurs.
If you have two exposures then you can compress those exposures with
more artistic freedom.
2008-10-08 by pr_roark
> ... I don't think there is an equivalent in the digital world.
I don't think the digital sensors have the "threshold" to overcome that
was, apparently, what was behind the pre-flashing effectiveness in film.
Some of us experimented briefly with filters to, in effect, "partition"
the RGB sensor.  See near the bottom of the page at
http://www.paulroark.com/BW-Info/
I didn't do much follow-up on this, but the use of filters with digital
cameras is still an area that intrigues me.  In addition to the
possibility of extending the dynamic range, I wonder about possible
effects on sharpness, perhaps by dealing with the color fringing.
> >  > pre-flashing of slide film we used to
2008-10-09 by Gary Weaver
I believe that shooting 3-color( three exposures) plates goes back to the earliest days of color photography. It seems to me, also, that this could be  quite useful with some exposures.
I often suggest to people that they experiment with filters, but I can't seem to follow my own advice  :  )
gar
*********** REPLY SEPARATOR  ***********
>Paul
>www.PaulRoark.com
>Please visit the Group Homepage to check the Files, and other resources as
>they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to
>unsubscribe, please edit your Membership preferences by visiting this same
>page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep
>them short.
>- Good manners are required at all time. No personal attacks or flames.
>Hostile, aggressive or argumentative users may be removed from the
>membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W
>printing. Users who persistently make off-topic posts may be removed from
>the membership.
>- By posting on this forum you agree to abide by the group rules and
>guidelines, and to abide by the actions and decisions of the group Owner
>and Moderators. See “Group Topic, Rules and Guidelines” in the Files
>section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
>YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
>“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
>EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
>PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
>“OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
>OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
>UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
>STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
>YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
