spoke too soon...paper still won't feed.
2008-10-21 by Sarah Renkes
I can't believe this. I can't get any paper to load from the front feeder at all. It either won't grab the paper or it just passes right through. I can load from the rear, but not smaller sizes. I'm ready to throw this thing away and I just got it. I'm almost sick with frustration. Sarah
2008-10-21 by the_des_bois
I run the same 3MK setup on an R1800. I sometimes get the front paper feeding problem you describe. Some days to a point of frustration. Many have described here ways of cleaning the "rubber paper grabbing" thing. It involves most of the time holding a sort of paper band with cleaning fluid on it. Or using some cleaning kits: http://www.staples.ca/ENG/Catalog/cat_sku.asp?CatIds=&webid=569277&affixedcode=WW I never got to doing it yet. I use the front loader for regular paper to run nozzle checks. All my prints are done on 200+ gsm paper that I feed from the rear. Even the 5x7 paper... Others who cleaned it succesfully will certainly give you more details. Don't give up!! :-) Denis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Sarah Renkes" <sagaface@...> wrote: > > I can't believe this. I can't get any paper to load from the front feeder at all. It either won't grab the paper or it just passes right through. I can load from the rear, but not smaller sizes. > > I'm ready to throw this thing away and I just got it. I'm almost sick with frustration.
> > Sarah >
Thanks for the words of encouragement, Denis. I LOVE the 13x19 image I just printed. 3MK is all that and a bag o' chips, for certain. I hope the r1800 doesn't let me down, now that I have finally been able to begin using these inks and workflow. I found a suggestion on another forum for cleaning the roller as you mentioned. Will try again tomorrow after it has dried completely. I had been atempting to use 4X6 Entrada 190 in the front feeder (tried one at a time, stacks, just a few...no difference.), with the thick paper box checked in the print dialog. Even plain paper spools through most of the time. Might try using the rear feeder. I take it that you have been successful just holding the paper straight to feed since the paper alignment thingy doesn't slide that far....? thanks again, Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "the_des_bois" <thedesbois@...> wrote: > > I run the same 3MK setup on an R1800. I sometimes get the front paper > feeding problem you describe. Some days to a point of frustration. > > Many have described here ways of cleaning the "rubber paper grabbing" > thing. It involves most of the time holding a sort of paper band with > cleaning fluid on it. Or using some cleaning kits: > > http://www.staples.ca/ENG/Catalog/cat_sku.asp? CatIds=&webid=569277&affixedcode=WW
> > I never got to doing it yet. I use the front loader for regular paper > to run nozzle checks. All my prints are done on 200+ gsm paper that I > feed from the rear. Even the 5x7 paper... > > Others who cleaned it succesfully will certainly give you more > details. Don't give up!! :-) > > Denis > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Sarah Renkes" > <sagaface@> wrote: > > > > I can't believe this. I can't get any paper to load from the front > feeder at all. It either won't grab the paper or it just passes right > through. I can load from the rear, but not smaller sizes. > > > > I'm ready to throw this thing away and I just got it. I'm almost > sick with frustration. > > > > Sarah > > >
> > Thanks for the words of encouragement, Denis. I LOVE the 13x19 image I just printed. > 3MK is all that and a bag o' chips, for certain. I hope the r1800 doesn't let me down, now > that I have finally been able to begin using these inks and workflow. and uses so much less ink than even the diluted inks workflows it makes ink cost a non issue! > > I had been atempting to use 4X6 Entrada 190 in the front feeder (tried one at a time, > stacks, just a few...no difference.), with the thick paper box checked in the print dialog. > Even plain paper spools through most of the time. Might try using the rear feeder. I take it > that you have been successful just holding the paper straight to feed since the paper alignment thingy doesn't slide that far....? I have never feed 4x6s. Only 5x7s. Yes hand alignment and using my finger to push the sheet... or a thin stick. Maybe I did do this with a 4x6... explaining the stick to push it into the printer. Denis
> > thanks again, > Sarah >
