Making yourown flushing cartridges
2008-11-29 by Brian Corll
If I were to make a set of flushing cartridges out of some refillable cartridges, what would I use as the flushing agent - just distilled H2O ? ----------------------------------------------------- Brian Corll [Non-text portions of this message have been removed]
2008-11-30 by dlruckus
Hi Brian. I've used a variety of things. The distilled water will work but it may be a bit more difficult to remove old ink that way. Currently, I use a mix of about 15% glycerin, 84.5% distilled H2O and 1/2% clear ammonia by volume. If I'm cleaning an old cart thats been around awhile or restoring an old printer's heads, I make the mix with about 10% Tilex Clean Shower replacing an equal amount of H2O (The Tilex contains a surfactant and isopropyl alcohol). Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll" <briancorll@...> wrote: > > If I were to make a set of flushing cartridges out of some refillable > cartridges, what would I use as the flushing agent - just distilled H2O ?
> > > > ----------------------------------------------------- > > Brian Corll > > > > [Non-text portions of this message have been removed] >
2008-11-30 by Robert Shram
Hi Duane Thanks for this information. The clear ammonia; how do you work that out? does it come in a pure form or is it in containers allready cut to say 3 to 10%? Thanks Bob Shram --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" <dlruckus@...> wrote: > > Hi Brian. I've used a variety of things. The distilled water will work > but it may be a bit more difficult to remove old ink that way. > Currently, I use a mix of about 15% glycerin, 84.5% distilled H2O and > 1/2% clear ammonia by volume. If I'm cleaning an old cart thats been > around awhile or restoring an old printer's heads, I make the mix with > about 10% Tilex Clean Shower replacing an equal amount of H2O (The > Tilex contains a surfactant and isopropyl alcohol). > > Regards > Duane > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll" > <briancorll@> wrote: > > > > If I were to make a set of flushing cartridges out of some refillable > > cartridges, what would I use as the flushing agent - just distilled
> H2O ? > > > > > > > > ----------------------------------------------------- > > > > Brian Corll > > > > > > > > [Non-text portions of this message have been removed] > > >
2008-11-30 by scott_now_coming
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll" <briancorll@...> wrote: > > If I were to make a set of flushing cartridges out of some refillable > cartridges, what would I use as the flushing agent - just distilled H2O ? > > > > ----------------------------------------------------- > > Brian Corll Hi Brian, I run 97% distilled water and 3% ammonia. Mix 3ml of ammonia with every 970 ml of distilled water. This is what I use to flush my 4800 once a year. If I were going to leave in the printer, such as in a B.O. set-up, I'd use just distilled water and use 3% glyceric instead of the ammonia. (I bought the glycerin at Wal_mart in pharmacy dept., that was 99.97% pure. It was only a few dollars for a 6oz. bottle.} Scott
2008-11-30 by Brian Corll
Thanks, Duane. Wow - Tilex - how did you come up with that one ? ! I'll give the glycerin, H2O and ammonia a spin. ----------------------------------------------------- Brian Corll
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of dlruckus Sent: Saturday, November 29, 2008 7:52 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re: Making yourown flushing cartridges Hi Brian. I've used a variety of things. The distilled water will work but it may be a bit more difficult to remove old ink that way. Currently, I use a mix of about 15% glycerin, 84.5% distilled H2O and 1/2% clear ammonia by volume. If I'm cleaning an old cart thats been around awhile or restoring an old printer's heads, I make the mix with about 10% Tilex Clean Shower replacing an equal amount of H2O (The Tilex contains a surfactant and isopropyl alcohol). Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Brian Corll" <briancorll@...> wrote: > > If I were to make a set of flushing cartridges out of some refillable > cartridges, what would I use as the flushing agent - just distilled H2O ? > > > > ----------------------------------------------------- > > Brian Corll > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]
2008-12-01 by dlruckus
Hi Bob. It's the ordinary clear ammonia from the grocery store so is precut. You wouldn't want it to be too corrosive. Be sure NOT to use some of the brands containing other additives. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Robert Shram" <bobshram@...> wrote:
> > Hi Duane > > Thanks for this information. The clear ammonia; how do you work that > out? does it come in a pure form or is it in containers allready cut > to say 3 to 10%? > > Thanks Bob Shram > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" > <dlruckus@> wrote: > > > > Hi Brian. I've used a variety of things. The distilled water will > work > > but it may be a bit more difficult to remove old ink that way. > > Currently, I use a mix of about 15% glycerin, 84.5% distilled H2O > and > > 1/2% clear ammonia by volume. If I'm cleaning an old cart thats been > > around awhile or restoring an old printer's heads, I make the mix > with > > about 10% Tilex Clean Shower replacing an equal amount of H2O (The > > Tilex contains a surfactant and isopropyl alcohol). > > > > Regards > > Duane > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll" > > <briancorll@> wrote: > > > > > > If I were to make a set of flushing cartridges out of some > refillable > > > cartridges, what would I use as the flushing agent - just > distilled > > H2O ? > > > > > > > > > > > > ----------------------------------------------------- > > > > > > Brian Corll > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > >
Brian,I was looking for commonly available products that contained surfactants possibly suitable for use in ink dilutions.The Tilex MSDS showed one of interest to me. That, along with the fact that it's only other listed ingredient besides H2O was the isopropyl, led me to give it a try. Unless you are a commercial or educational enterprise, it's often difficult to get access to small quantities of this sort of chemical. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll" <briancorll@...> wrote: > > Wow - Tilex - how did you come up with that one ? ! > > > > ----------------------------------------------------- > > Brian Corll > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of dlruckus
> Sent: Saturday, November 29, 2008 7:52 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Re: Making yourown flushing cartridges > > > > Hi Brian. I've used a variety of things. The distilled water will work > but it may be a bit more difficult to remove old ink that way. > Currently, I use a mix of about 15% glycerin, 84.5% distilled H2O and > 1/2% clear ammonia by volume. If I'm cleaning an old cart thats been > around awhile or restoring an old printer's heads, I make the mix with > about 10% Tilex Clean Shower replacing an equal amount of H2O (The > Tilex contains a surfactant and isopropyl alcohol). > > Regards > Duane > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Brian Corll" > <briancorll@> wrote: > > > > If I were to make a set of flushing cartridges out of some refillable > > cartridges, what would I use as the flushing agent - just distilled > H2O ? > > > > > > > > ----------------------------------------------------- > > > > Brian Corll > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] >
2008-12-01 by dgattarino
Ammonia is bad for the plastics in the printer head. Use just distilled water, glycerin and a cleaner containing only surfactants (like Simple Green). Daniela
2008-12-01 by robert shram
Thanks Daniela, thats usefull information and I will do just that. Bob Shram ________________________________
From: dgattarino <dgattarino@yahoo.com> To: DigitalBlackandWhiteThePrint@yahoogroups.com Sent: Monday, December 1, 2008 11:28:56 AM Subject: [Digital BW] Re: Making yourown flushing cartridges Ammonia is bad for the plastics in the printer head. Use just distilled water, glycerin and a cleaner containing only surfactants (like Simple Green). Daniela [Non-text portions of this message have been removed]
2008-12-02 by pr_roark
"dlruckus" <dlruckus@...> wrote: > > ... I was looking for commonly available products that contained > surfactants possibly suitable for use in ink dilutions. > The Tilex MSDS showed one of interest to me. > That, along with the fact that it's only > other listed ingredient besides H2O was the isopropyl, > led me to give it a try. It does have fragrances in it. > Unless you are a commercial or educational enterprise, it's > often difficult to get access to small quantities of this sort of > chemical. Edwal LFN wetting agent is a relatively concentrated possibility that has been used for photography for some time. See http://www.digitaltruth.com/products/msds/LFNWettingAgent.pdf It appears to have 3 different ethoxylated linear alcohols (<35%) as well as isopropyl (<15%). These types of alcohols are mentioned often with respect to inkjet and other surfactant needs. I mention it mostly because it is one of the possibilities I've considered testing for use in inks. I have not yet tried it. Paul www.PaulRoark.com
2008-12-02 by dlruckus
Thanks Paul. I believe Tilex has changed the formulation of their product since I first used it. I just looked at a new bottle in the grocery store and see that it now has tetrapotassium EDTA listed on the bottle as well. The original supply I have been using did not show that. It's surfactant was alkyl polyglycoside along with the isopropyl alcohol. Both in a range of 1 to 5%. Interestingly enough, a search on this surfactant led to studies showing that it functioned in much the same way as the polymer coatings you mentioned the other day, when used in small concentrations. It surface coats the particles and prevents clumping. I haven't yet had time to do much work with it but did use it to make a base dilution for your carbon six set just to tinker. One thing I did observe was that it took some time for it to do it's thing. The initial mix tended to leave a thin coat of pigment on the side of the poly bottle, as do all of the inks I've seen to date. However, after sitting for a couple of days, there was a marked change and that no longer happened. The ink now drains completely into the bottom and no longer leaves any residue on the side of the bottle. Sometime over the next few months I'll investigate it a bit more. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> > "dlruckus" <dlruckus@> wrote: > > > > ... I was looking for commonly available products that contained > > surfactants possibly suitable for use in ink dilutions. > > The Tilex MSDS showed one of interest to me. > > That, along with the fact that it's only > > other listed ingredient besides H2O was the isopropyl, > > led me to give it a try. > > It does have fragrances in it. > > > Unless you are a commercial or educational enterprise, it's > > often difficult to get access to small quantities of this sort of > > chemical. > > Edwal LFN wetting agent is a relatively concentrated possibility that > has been used for photography for some time. See > http://www.digitaltruth.com/products/msds/LFNWettingAgent.pdf > > It appears to have 3 different ethoxylated linear alcohols (<35%) as > well as isopropyl (<15%). These types of alcohols are mentioned > often with respect to inkjet and other surfactant needs. > > I mention it mostly because it is one of the possibilities I've > considered testing for use in inks. I have not yet tried it. > > Paul > www.PaulRoark.com >
Duane wrote: > I believe Tilex has changed the formulation ... > it now has tetrapotassium EDTA listed ... > It's surfactant was alkyl polyglycoside along with > the isopropyl alcohol. Both in a range of 1 to 5%. > Interestingly enough, a search on this surfactant led to studies > showing that it functioned in much the same way as the polymer > coatings you mentioned the other day, when used in small > concentrations. It surface coats the particles and prevents > clumping. These surfactants are where a whole lot of action is. They all coat things. It's how they work. With one end being hydrophobic (not liking water) and one end being hydrophilic (liking water), they tend to line up at the edges of water and other substances, including pigment particles. All of our pigment particles have always been "coated" in this sense. Balancing the various characteristics of these substances to get the gloss (or lack thereof), dispersion/stabilization, and adhesion one is after is how the various companies pay their bills. Although finding the cocktail that does what one wants becomes very tricky with the pigments, for cleaning I suspect a lot of them will work well. > ... The ink now drains completely into the bottom and no > longer leaves any residue on the side of the bottle. Interesting. Paul www.PaulRoark.com
2008-12-02 by scott_now_coming
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote: > > Duane wrote: > > > I believe Tilex has changed the formulation ... > > it now has tetrapotassium EDTA listed ... > > It's surfactant was alkyl polyglycoside along with > > the isopropyl alcohol. Both in a range of 1 to 5%. > > > Interestingly enough, a search on this surfactant led to studies > > showing that it functioned in much the same way as the polymer > > coatings you mentioned the other day, when used in small >> > ... The ink now drains completely into the bottom and no > > longer leaves any residue on the side of the bottle. > > Interesting. > > Paul > www.PaulRoark.com > Paul, Do you think Jet-Dry would work as a surfactant? It has a nonionic chemical I believe is polyoxyethylene, which I also belive is the same as polyoxyethyl alcohol used in Photo-Flo 200. I bet Jet Dry would work at least as well as PF 200. Scott
Scott wrote: ... > Do you think Jet-Dry would work as a surfactant? It has a nonionic > chemical I believe is polyoxyethylene, which I also belive is the > same as polyoxyethyl alcohol used in Photo-Flo 200. > > I bet Jet Dry would work at least as well as PF 200. > I don't know. I suspect there are a number of these that will work in the older printers. The 1.5 pl printers may be more difficult to get to print smoothly. I used Photo Flo in the first C6 iteration because many of us have it, and I thought people might be more accepting of a chemical that has been used in the field for many years. Paul www.PaulRoark.com
2008-12-03 by Paul Whiting
Don't know if this is germane to the topic, but I do traditional b/w photography and have switched from PhotoFlo to LFN for my film development. PhotoFlo, if mixed and left to stand, gets "skanky", stuff begins to grow in it. I was careful in using it, but sometimes I got scum on my negatives. Since using LFN I've had none of these problems. In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
2008-12-03 by Gary Weaver
I use ammonia dilute for outside cleaning (strong). It is a strong compound that should be used with care. I still use vinegar dilute for mild cleaning (windows). gar *********** REPLY SEPARATOR ***********
On 12/1/2008 at 4:28 PM dgattarino wrote: >Ammonia is bad for the plastics in the printer head. Use just >distilled water, glycerin and a cleaner containing only surfactants >(like Simple Green). > >Daniela > > >------------------------------------ > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. >Yahoo! Groups Links > > >
2008-12-03 by dlruckus
Moderation is the word of course, but there is no need to fear low levels of use. Ammonia is listed frequently in patent literature as an ingredient in inks for inkjets. If memory serves, it was even mentioned here as a component in at least one MIS ink base. I've been using it, at low levels, for cleaning both outside and inside of my machines for nearly a decade now. I'm still using the first Epson I purchased. It gets mothballed for 6 months of every year and the heads cleaned with flushing fluid containing ammonia prior to it's use. There have been no problems from doing that. The same is true for the other 4 machines I own. After all, if you buy it in the grocery, it even comes in a plastic bottle and gets stored on the laundry shelf for who knows how long without problem :) Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver" <garww@...> wrote: > > I use ammonia dilute for outside cleaning (strong). It is a strong compound that should be used with care. I still use vinegar dilute for mild cleaning (windows). > > gar > > *********** REPLY SEPARATOR *********** > > On 12/1/2008 at 4:28 PM dgattarino wrote: > > >Ammonia is bad for the plastics in the printer head. Use just > >distilled water, glycerin and a cleaner containing only surfactants > >(like Simple Green). > > > >Daniela > > > > > >------------------------------------ > > > >Please visit the Group Homepage to check the Files, and other resources as > >they are often being updated. > > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > >If you wish to receive no emails or just a daily digest, or you wish to > >unsubscribe, please edit your Membership preferences by visiting this same > >page. > > > >Please follow these basic guidelines: > >- As threads develop, trim off excess portions of earlier messages to keep > >them short. > >- Good manners are required at all time. No personal attacks or flames. > >Hostile, aggressive or argumentative users may be removed from the > >membership without notice. > >- Keep your posts and threads related to the group topic of digital B&W > >printing. Users who persistently make off-topic posts may be removed from > >the membership. > >- By posting on this forum you agree to abide by the group rules and > >guidelines, and to abide by the actions and decisions of the group Owner > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > >section: > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > >PRINT YAHOO GROUP. > >Yahoo! Groups Links > > > > > > >
2008-12-04 by p5198
Good to know, Duane. But what do you do about the excess ink pads after you've reset the printer a couple of times and the pads genuinely need changing? Bob Bollini --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" <dlruckus@...> wrote: > > Moderation is the word of course, but there is no need to fear low > levels of use. Ammonia is listed frequently in patent literature as an > ingredient in inks for inkjets. If memory serves, it was even > mentioned here as a component in at least one MIS ink base. > > I've been using it, at low levels, for cleaning both outside and > inside of my machines for nearly a decade now. I'm still using the > first Epson I purchased. It gets mothballed for 6 months of every year > and the heads cleaned with flushing fluid containing ammonia prior to > it's use. There have been no problems from doing that. The same is > true for the other 4 machines I own. > > After all, if you buy it in the grocery, it even comes in a plastic > bottle and gets stored on the laundry shelf for who knows how long > without problem :) > > Regards > Duane > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver" > <garww@> wrote: > > > > I use ammonia dilute for outside cleaning (strong). It is a strong > compound that should be used with care. I still use vinegar dilute for > mild cleaning (windows). > > > > gar > > > > *********** REPLY SEPARATOR *********** > > > > On 12/1/2008 at 4:28 PM dgattarino wrote: > > > > >Ammonia is bad for the plastics in the printer head. Use just > > >distilled water, glycerin and a cleaner containing only surfactants > > >(like Simple Green). > > > > > >Daniela > > > > > > > > >------------------------------------ > > > > > >Please visit the Group Homepage to check the Files, and other > resources as > > >they are often being updated. > > > > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > >If you wish to receive no emails or just a daily digest, or you wish to > > >unsubscribe, please edit your Membership preferences by visiting > this same > > >page. > > > > > >Please follow these basic guidelines: > > >- As threads develop, trim off excess portions of earlier messages > to keep > > >them short. > > >- Good manners are required at all time. No personal attacks or flames. > > >Hostile, aggressive or argumentative users may be removed from the > > >membership without notice. > > >- Keep your posts and threads related to the group topic of digital B&W > > >printing. Users who persistently make off-topic posts may be > removed from > > >the membership. > > >- By posting on this forum you agree to abide by the group rules and > > >guidelines, and to abide by the actions and decisions of the group > Owner > > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > > >section: > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT > > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > LIABLE TO > > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) > THE USE > > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; > (iii) > > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > > >PRINT YAHOO GROUP. > > >Yahoo! Groups Links > > > > > > > > > > > >
2008-12-05 by dlruckus
Hello Bob. You may have noticed that I said I have 5 printers. I use all of them but print only for myself, so, they are not in a high production environment compared to a commercial one or even someone using only one printer for everything. Also, I work from 2 different locations during the year so they all get a long rest at some point. It takes considerable time for cleaning cycles to fill up a sump, especially if one takes the trouble to avoid using any more of them than necessary, and the flushing fluids and all but pigment residues tend to basically evaporate away during the periodic rests. I reset machines but I keep track of what the pads look like and have yet to overflow anything. I repair and maintain the printers myself so if pads need replaced, I just do it. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "p5198" <oyster@...> wrote: > > Good to know, Duane. But what do you do about the excess ink pads > after you've reset the printer a couple of times and the pads > genuinely need changing? > Bob Bollini > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" > <dlruckus@> wrote: > > > > Moderation is the word of course, but there is no need to fear low > > levels of use. Ammonia is listed frequently in patent literature as an > > ingredient in inks for inkjets. If memory serves, it was even > > mentioned here as a component in at least one MIS ink base. > > > > I've been using it, at low levels, for cleaning both outside and > > inside of my machines for nearly a decade now. I'm still using the > > first Epson I purchased. It gets mothballed for 6 months of every year > > and the heads cleaned with flushing fluid containing ammonia prior to > > it's use. There have been no problems from doing that. The same is > > true for the other 4 machines I own. > > > > After all, if you buy it in the grocery, it even comes in a plastic > > bottle and gets stored on the laundry shelf for who knows how long > > without problem :) > > > > Regards > > Duane > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver" > > <garww@> wrote: > > > > > > I use ammonia dilute for outside cleaning (strong). It is a strong > > compound that should be used with care. I still use vinegar dilute for > > mild cleaning (windows). > > > > > > gar > > > > > > *********** REPLY SEPARATOR *********** > > > > > > On 12/1/2008 at 4:28 PM dgattarino wrote: > > > > > > >Ammonia is bad for the plastics in the printer head. Use just > > > >distilled water, glycerin and a cleaner containing only surfactants > > > >(like Simple Green). > > > > > > > >Daniela > > > > > > > > > > > >------------------------------------ > > > > > > > >Please visit the Group Homepage to check the Files, and other > > resources as > > > >they are often being updated. > > > > > > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > > > >If you wish to receive no emails or just a daily digest, or you > wish to > > > >unsubscribe, please edit your Membership preferences by visiting > > this same > > > >page. > > > > > > > >Please follow these basic guidelines: > > > >- As threads develop, trim off excess portions of earlier messages > > to keep > > > >them short. > > > >- Good manners are required at all time. No personal attacks or > flames. > > > >Hostile, aggressive or argumentative users may be removed from the > > > >membership without notice. > > > >- Keep your posts and threads related to the group topic of > digital B&W > > > >printing. Users who persistently make off-topic posts may be > > removed from > > > >the membership. > > > >- By posting on this forum you agree to abide by the group rules and > > > >guidelines, and to abide by the actions and decisions of the group > > Owner > > > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > > > >section: > > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > > PRINT > > > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > > > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > > LIABLE TO > > > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > > > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > > > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > > > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP > HAVE BEEN > > > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) > > THE USE > > > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > > > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; > > (iii) > > > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > > > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> > > >PRINT YAHOO GROUP. > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > >
2008-12-05 by Paul Banks
Regarding you posting, you mention you replace the pads yourself. I didn't realise it was possible to buy the pads without being an authorised Epson Service Centre. Can you please direct me as to where I may buy the pads please? Additionally, is there a publication that explains how to service the printers? We have over twenty printers we use for testing inks periodically, so this would be really useful. Many thanks Paul ________________________________
Sent: Friday, 5 December, 2008 0:34:51
overflow anything.
just do it.
Duane
--- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "p5198"
> Bob Bollini
> --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "dlruckus"
> > without problem :)
> > Regards
> > Duane
> > --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "Gary Weaver"
> > > gar
> > > >Daniela
> > resources as
> > > >http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt
> wish to
> > this same
> > > >page.
> > to keep
> > > >them short.
> flames.
> digital B&W
> > removed from
> > > >the membership.
rules and
> > Owner
Files
> > > >section:
> > > >http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt/files/
> > PRINT
"OWNER" AND
> > LIABLE TO
LOSS OF
IF THE
> HAVE BEEN
> > THE USE
> > (iii)
PRINT
BW, THE
> > > >PRINT YAHOO GROUP.
> > > >Yahoo! Groups Links
[Non-text portions of this message have been removed]2008-12-05 by dlruckus
Hello Paul. Google "epson service manual" and "epson parts" to find sources for both. I don't know where you are located, but if you are in the USA and unless the law has been changed, it's been illegal for a company to refuse to sell parts to customers for equipment that they have legally purchased, for a period of seven years from the time of the last company sale of the item to anyone in the country. I suspect that the law is honored only in the breach much of the time since one might have to force their attention to it. It's also illegal to require anyone to use only "authorized service" for something or to refuse to honor the warranty do to use of third party supplies in a machine. The burden of proof would be upon Epson for any assertion on their part that the supplies cause damage of some sort. Again, of course, anything goes if customers allow someone to get away with breaking those laws. More to the point is that you would want to have someone in your organization with some experience in repairs of electro-mechanical devices in order to achieve much benefit from the DIY approach. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Banks <failedthespian@...> wrote: > > Regarding you posting, you mention you replace the pads yourself. I didn't realise it was possible to buy the pads without being an authorised Epson Service Centre. Can you please direct me as to where I may buy the pads please? > > Additionally, is there a publication that explains how to service the printers? > > We have over twenty printers we use for testing inks periodically, so this would be really useful. > > Many thanks > > Paul > > > > > ________________________________ > From: dlruckus <dlruckus@...> > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Sent: Friday, 5 December, 2008 0:34:51 > Subject: [Digital BW] Re: Making yourown flushing cartridges > > > Hello Bob. You may have noticed that I said I have 5 printers. I use > all of them but print only for myself, so, they are not in a high > production environment compared to a commercial one or even someone > using only one printer for everything. Also, I work from 2 different > locations during the year so they all get a long rest at some point. > It takes considerable time for cleaning cycles to fill up a sump, > especially if one takes the trouble to avoid using any more of them > than necessary, and the flushing fluids and all but pigment residues > tend to basically evaporate away during the periodic rests. I reset > machines but I keep track of what the pads look like and have yet to > overflow anything. > > I repair and maintain the printers myself so if pads need replaced, I > just do it. > > Regards > Duane > > --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "p5198" > <oyster@> wrote: > > > > Good to know, Duane. But what do you do about the excess ink pads > > after you've reset the printer a couple of times and the pads > > genuinely need changing? > > Bob Bollini > > > > --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "dlruckus" > > <dlruckus@> wrote: > > > > > > Moderation is the word of course, but there is no need to fear low > > > levels of use. Ammonia is listed frequently in patent literature as an > > > ingredient in inks for inkjets. If memory serves, it was even > > > mentioned here as a component in at least one MIS ink base. > > > > > > I've been using it, at low levels, for cleaning both outside and > > > inside of my machines for nearly a decade now. I'm still using the > > > first Epson I purchased. It gets mothballed for 6 months of every year > > > and the heads cleaned with flushing fluid containing ammonia prior to > > > it's use. There have been no problems from doing that. The same is > > > true for the other 4 machines I own. > > > > > > After all, if you buy it in the grocery, it even comes in a plastic > > > bottle and gets stored on the laundry shelf for who knows how long > > > without problem :) > > > > > > Regards > > > Duane > > > > > > --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "Gary Weaver" > > > <garww@> wrote: > > > > > > > > I use ammonia dilute for outside cleaning (strong). It is a strong > > > compound that should be used with care. I still use vinegar dilute for > > > mild cleaning (windows). > > > > > > > > gar > > > > > > > > *********** REPLY SEPARATOR *********** > > > > > > > > On 12/1/2008 at 4:28 PM dgattarino wrote: > > > > > > > > >Ammonia is bad for the plastics in the printer head. Use just > > > > >distilled water, glycerin and a cleaner containing only surfactants > > > > >(like Simple Green). > > > > > > > > > >Daniela > > > > > > > > > > > > > > >----------- --------- --------- ------- > > > > > > > > > >Please visit the Group Homepage to check the Files, and other > > > resources as > > > > >they are often being updated. > > > > > > > > > >http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt > > > > > > > > > >If you wish to receive no emails or just a daily digest, or you > > wish to > > > > >unsubscribe, please edit your Membership preferences by visiting > > > this same > > > > >page. > > > > > > > > > >Please follow these basic guidelines: > > > > >- As threads develop, trim off excess portions of earlier messages > > > to keep > > > > >them short. > > > > >- Good manners are required at all time. No personal attacks or > > flames. > > > > >Hostile, aggressive or argumentative users may be removed from the > > > > >membership without notice. > > > > >- Keep your posts and threads related to the group topic of > > digital B&W > > > > >printing. Users who persistently make off-topic posts may be > > > removed from > > > > >the membership. > > > > >- By posting on this forum you agree to abide by the group > rules and > > > > >guidelines, and to abide by the actions and decisions of the group > > > Owner > > > > >and Moderators. See "Group Topic, Rules and Guidelines" in the > Files > > > > >section: > > > > >http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt/files/ > > > > > > > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > > > PRINT > > > > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > "OWNER" AND > > > > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > > > LIABLE TO > > > > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > > > > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR > LOSS OF > > > > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN > IF THE > > > > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP > > HAVE BEEN > > > > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) > > > THE USE > > > > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > > > > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
> > > (iii) > > > > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE > PRINT > > > > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL > BW, THE > > > > >PRINT YAHOO GROUP. > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
2008-12-06 by Tony Sleep
On 05/12/2008 Paul Banks wrote: > I didn't realise it was possible to buy the pads without being an > authorised Epson Service Centre. Can you please direct me as to where > I may buy the pads please? Epson distribute spares through several UK outlets, the main one being Unicomp Ltd 01732 781400 Bourne Estate Borough Green TN15 8DG They were perfectly happy to sell spare parts to me, an end user, taking CC payment over the phone for a 1290 printhead, which I DIY replaced at half the cost of Epson doing it (easy 10min job, no calibration required except normal user stuff on that printer). Whether they sell manuals I don't know. -- Regards Tony Sleep http://tonysleep.co.uk
2008-12-09 by Tyler Boley
I've been following this thread for a bit... thanks to all with knowledge... but before I mix up a big Christmas batch, I'm unclear about part of it... I'm trying the glycerin, distilled water, but from there I'm unclear if what tilex and simple green offer are interchangable... or do they each offer something unique? Lastly, the tilex I saw in the store had the fragrence Paul mentioned, but does that rule it out? Stinks around here anyway... Thanks all, Tyler
2008-12-11 by dlruckus
Hi Tyler. Looking at the MSDS of each of these products, it appears the difference is that the primary ingredient of Simplegreen is Butyl Cellosolve, a solvent, along with fragrances also, whereas the Tilex Fresh Shower has Alkylpolyglycoside, which is an environment friendly non-ionic surfactant, along with alcohol as solvent, a chelating EDTA agent to bind heavy metals, and fragrance. Try googling Butyl cellosolve to get an idea of it's disadvantages. The surfactant in the Tilex is used in many cleaning and cosmetic products from what I can find. It's also mentioned in research and patent literature as very useful in micro encapsulation applications. That caught my attention quickly. It's also effective in basic solutions which include some of the inks we use. One other advantage it has is that it leaves no residues behind and requires no rinse when used in cleaning applications. All this said, I imagine a lot of cleaning agents can probably be used successfully. I don't think the fragrances have much impact for the flushing use but for dilution of inks the jury would still be out. Sorry for the late response but I've been under the weather for a couple of days(due to an encounter with a poisonous spider...it won). Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> > I've been following this thread for a bit... thanks to all with > knowledge... but before I mix up a big Christmas batch, I'm unclear > about part of it... I'm trying the glycerin, distilled water, but from > there I'm unclear if what tilex and simple green offer are > interchangable... or do they each offer something unique? Lastly, the > tilex I saw in the store had the fragrence Paul mentioned, but does > that rule it out? Stinks around here anyway... > Thanks all, > Tyler >
2008-12-11 by Tyler Boley
Good grief, that sounds awful! I hope you are OK Duane. I really apreciate your reply. The only thing I might add for anyone else following this is that there are 2 tilex products that I ran into. One seems to be for mold, NOT what you want. Thanks again Duane, get better. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" <dlruckus@...> wrote:
> > Hi Tyler. > Looking at the MSDS of each of these products, it appears the > difference is that the primary ingredient of Simplegreen is Butyl > Cellosolve, a solvent, along with fragrances also, whereas the Tilex > Fresh Shower has Alkylpolyglycoside, which is an environment friendly > non-ionic surfactant, along with alcohol as solvent, a chelating EDTA > agent to bind heavy metals, and fragrance. > Try googling Butyl cellosolve to get an idea of it's disadvantages. > > The surfactant in the Tilex is used in many cleaning and cosmetic > products from what I can find. It's also mentioned in research and > patent literature as very useful in micro encapsulation applications. > That caught my attention quickly. It's also effective in basic > solutions which include some of the inks we use. One other advantage > it has is that it leaves no residues behind and requires no rinse when > used in cleaning applications. > > All this said, I imagine a lot of cleaning agents can probably be used > successfully. I don't think the fragrances have much impact for the > flushing use but for dilution of inks the jury would still be out. > > Sorry for the late response but I've been under the weather for a > couple of days(due to an encounter with a poisonous spider...it won). > > Regards > Duane > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" > <tyler@> wrote: > > > > I've been following this thread for a bit... thanks to all with > > knowledge... but before I mix up a big Christmas batch, I'm unclear > > about part of it... I'm trying the glycerin, distilled water, but from > > there I'm unclear if what tilex and simple green offer are > > interchangable... or do they each offer something unique? Lastly, the > > tilex I saw in the store had the fragrence Paul mentioned, but does > > that rule it out? Stinks around here anyway... > > Thanks all, > > Tyler > > >
2008-12-13 by Mark MacKenzie
Hi Duane <...whereas the Tilex <Fresh Shower has Alkylpolyglycoside, which is an environment friendly <non-ionic surfactant, along with alcohol as solvent, a chelating EDTA <agent to bind heavy metals, and fragrance I would stay away from anything containing EDTA if it is to pass through precision, reasonably fragile metallic components such as the piezo heads. EDTA will definitely erode copper, zinc, iron, etc. Yes it will be little bits but continued use will accrue and such precision and intricate things as piezo heads don't need much internal erosion before the clog from hell arrives or they don't function as well as they ought to. EDTA and its cousins are all part of my art conservation chemical shelf. My two cents. Mark MacKenzie Art Conservator & Wet Plate Photographer Alcalde, New Mexico [Non-text portions of this message have been removed]
2008-12-13 by dlruckus
Hi Mark. Thanks for the info. It's appreciated. Regards Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark MacKenzie" <mjmackenzie22@...> wrote: > > Hi Duane > > <...whereas the Tilex > <Fresh Shower has Alkylpolyglycoside, which is an environment friendly > <non-ionic surfactant, along with alcohol as solvent, a chelating EDTA > <agent to bind heavy metals, and fragrance > > I would stay away from anything containing EDTA if it is to pass through precision, reasonably fragile metallic components such as the piezo heads. EDTA will definitely erode copper, zinc, iron, etc. Yes it will be little bits but continued use will accrue and such precision and intricate things as piezo heads don't need much internal erosion before the clog from hell arrives or they don't function as well as they ought to.
> > EDTA and its cousins are all part of my art conservation chemical shelf. > > My two cents. > > > Mark MacKenzie > Art Conservator & Wet Plate Photographer > Alcalde, New Mexico > > [Non-text portions of this message have been removed] >
