> It may be that the 1400 chips from MIS are auto-reset, the 1800 chips
> I have are not. Maybe it's the mixing of auto-reset and not auto-
> reset chips that triggers the problem.
> Paul
> www.PaulRoark.com
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Andrew Sharpe
> <asharpe@> wrote:
> > >>> As a matter of fact I have OEM Epson PK and Y in my R1800 now
> with MIS
> > >>> inks in the other spots. No problems here.
> > Interesting. I wanted to try putting an Eboni K and leaving the OEM
> > colors in my 1400, but Paul said it wouldn't fly because you
> couldn't
> > mix OEM and 3rd party carts. I wonder why the 1800 allows it, and
> the
> > 1400 doesn't?
> > Andrew
> > > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, "Roger"
> > > <rsmith02@> wrote:
> > >> I don't think any purge is needed, except maybe going from MK in
> the
> > >> glop position back to glop.
> with MIS
> > >> You need a full set of cartridges installed (can be just cleaning
> > >> carts in the non MK positions) to print anything.
> > > Roger,thanks for your reply.
> > > Can i use the oem color cartridges if I so choose ?
> > > Do you use the MIS color carts because they are more archival??
> > >> "gerardthomas517x" <gerardthomas517x@> wrote:
> > >> > I am interested in starting to print some b&w on the 1800
> > >> > printer.I've read/re-read most of the info i could find,and
> I'm still
> > >> > not quite sure exactly what step to take first..
> > >> > On the inksupply .com website ,it says"that oem epson ink is
> > >> > compatible with the black inks from MIS",and that no cleaning
> is
> > >> > necessary.
> > >> > Then on another page it states that cleaning is mandatory.
> > >> > 1.do I need to remove all of the oem inks,and purge the
> printer of oem
> > >> > ink,first?
> > >> > 2..After purging the ink,do I put the oem color catridges back
> in the
> > >> > printer ,or leave them out?
> > >> > 3. Do I print with the 3 black cartridges only?
> > >> > Any advise /help would be appreciated
> > >> > Thanks for your patience
> > >> > Mike
