Carbon 7b with 10% UCMK
2008-12-03 by pr_roark
My latest experiement with an open source, reasonably cheap carbon
printing setup uses a warm midtone 10% mix of UC MK.  The UCMK was
diluted with the C6 base.
See http://www.paulroark.com/BW-Info/Ink-Mixing.pdf
For more details of the resulting inkset,see
http://www.paulroark.com/BW-Info/Carbon-7b-2200-10pcUCMK.pdf
While I used Eb6-Y in this iteration, C6-Y would preform essentially
the same way in 4 pl printers (at least given what I've seen in the
approximate year I've been working with both Eboni dilution bases).
For UC MK I just pull ink from a 7600 MK cart, using my usual
modified bottom fill adapter.
See http://www.paulroark.com/BW-Info/Modified-Bottom-Fill-Adapter.pdf
I'm using a centrifuge to try and obtain information regarding rate
of settlement, which also translates into resistance to
flocculation/agglomeration.  Going forward, doing well in the
centrifuge will be a regular factor in where I go.  They all settle,
but some are better than others.
This is not a recommendation that others go this route, but just a
note on my latest experiements.
