Viewing Lights
Viewing Lights
2008-12-25 by Brian Corll
General question: If you use special lighting for viewing your prints,
what's your preferred light ? I'm thinking of getting/making something but
there are so many choices. What is everyone else using, if anything ?
Brian Corll
Re: [Digital BW] Viewing Lights
2008-12-25 by Peter De Smidt
Ideally you view the print in the light that it's going to be displayed
in.  If you don't know what that'll be, then a daylight viewing booth
can be handy.  You might consider making a booth that can switch between
tungsten light and high cri fluorescent bulbs.
Re: Viewing Lights
2008-12-25 by Louis Dina
Brian,
The answer (in my opinion) depends on what you are trying to achieve.
 If you want to go with an industry standard so your lights match what
your local commercial printer is using, you are better off with a
viewing booth, or using lights that approach the D50 standard.  Solux
sells bayonet mount lights that are the closest I have found to D50.
http://www.solux.net/cgi-bin/tlistore/infopages/color-proofing.html
Also, Philips sells some fluorescent bulbs that are very good.
http://www.bulbs.com/eSpec.aspx?ID=9361&Ref=Light+Bulbs&RefId=14
GTI and others make viewing booths, but they are generally pretty
expensive.
Solux and others also make lights that are or a warmer temperature
than D50, but not as warm as incandescent, which are often used in
galleries, museums, etc.
For my personal usage, I used the Solux 4700K bulbs in a Solux light
fixture, and also the Philips TL950 series fluorescent tubs(in a
standard fluorescent fixture that I bought at Home Depot).
One of the most important considerations in proofing is adjusting the
light source so that a sheet of white paper displays approximately as
bright under the light, as does a white document displayed on your
monitor in Photoshop.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll"
something but
2008-12-26 by Andrew Darlow
Hi Brian:
Lighting is such an important part of proofing and viewing any print.
I really like the original Solux Task Lamp, which comes with a SoLux
4700K 50W bulb:
https://www.solux.net/cgi-bin/tlistore/19115.html
They also have a:
Clamp on Goose Neck Fixture without bulb: $69
(bulbs are about $10 ea)
and a Clip on Fixture with SoLux 4700K 50W bulb: $54.90
I wrote an article that includes some additional lighting info here:
http://tinyurl.com/2b3gfo
Which color temp to choose? I would use the 4700k and then purchase a
3500k to simulate a typical home or office track light system. It is
"safer" to proof under 4700k because if you proof under 3500k, there
is a good possibility your work will be viewed under daylight, which
will tend to make it look cool (or even greenish).
I've been using GTI fluorescent boxes for years and they produce a
decent light, but they have spikes and the light is too flat for my
taste when looking at inkjet prints (especially on matte papers).
All the best,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://
www.inkjettips.com
> something but
> Brian Corll
> __
2008-12-26 by Ernst Dinkla
Related to this list,  there are some Solux users that
prefer the 4100K version for B&W prints.
The Philips Diamondline 12V,  5.3 GU, Halogen, 50 and 35
watt, 3500, 4100, 4700
Kelvin.are made with a license from Solux.  They are easier
to get in Europe.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-12-26 by Eugene Coggins
If you are in the US., Home Depot sells both CF
and different size tubes that are 5000°K.
Gene
>Brian Corll
2008-12-26 by Louis Dina
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Eugene Coggins
> Gene
True enough, but unless they have changed since the last time I bought
those, they have a fairly low CRI (ie, Color Rendering Index) in the
80's.  They are fairly "spikey".  Perhaps they are stocking different
lights now.
Lou
The ones I purchased have an CRI of 95 which is good enough.
80 is very very bad. Your are correct. Anything below 93 is considered poor.
Gene
>-- In
><mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>DigitalBlackandWhiteThePrint@yahoogroups.com,
>Eugene Coggins
>>  Gene
>lights now.
>Lou
2008-12-26 by pr_roark
Hi Gene,
That's impressive.  Are these CF floods or spots?  Do you have a
source?  I'm trying to upgrade Gallery Los Olivos' lighting.
2008-12-27 by Eugene Coggins
Paul:
They are only the fluorescent tubes that are
labeled Natural Sunshine. The tubes I am using I
bought three years ago from Home Depot.
The CRI are not known or shown on the CF bulbs.
Only the tubes show a CRI. The tubes run about
$5+ per tube. I have installed the 5000° K tubes
in my entire work space. It's better than looking
at your prints under incandescent bulbs or a cool
white fluorescent light. And the price is right.
However, I am sure Solux makes a superior bulb or
tube, but at a much higher price.
The usual option for galleries is halogen bulbs
that are around 3800°K. Which is better than
incandescent floods at 2700°K.
Gene
>Hi Gene,
>Thanks,
>Paul
>www.PaulRoark.com<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/join;_ylc=X3oDMTJmMjNnYWU4BF9TAzk3MzU5NzE0BGdycElkAzM3MDIzMTEEZ3Jwc3BJZAMxNzA1MDE5MTgyBHNlYwNmdHIEc2xrA3N0bmdzBHN0aW1lAzEyMzAzMjU0NTY->Change
>settings via the Web (Yahoo! ID required)
Re: Viewing Lights
2008-12-27 by hjswim2@aol.com
I use Solux spots. Left fluorescents behind a long time ago.
I bought ceiling light adapters and also clip-ons. Clip-ons are great because
you can attach them to light stands or any other object any way you want. I
even have one clipped to a rack and shining down on the printer exit to check
how the print is looking as it comes out.
Bulbs comes in 4700K (approximates D50), 4100K, 3500K.
CRIs are 98-99.
Variable beamspread.
If they're good enough for the Guggenheim Museum and the National Gallery of
Art, they're good enough for me. ;-)
www.solux.net
(I have no connection)
Harald
One site keeps you connected to all your email: AOL Mail,
Gmail, and Yahoo Mail. Try it now. (http://www.aol.com/?optin=new-dp&
icid=aolcom40vanity&ncid=emlcntaolcom00000025)
2008-12-27 by pr_roark
> labeled Natural Sunshine. ...
To qualify for the "Energy Saver" (I think) label the CRI must be at
least 80, I'm told.
>... I have installed the 5000° K tubes ...
There is an interesting relationship between light levels and color
temperature that is often expressed by a curve called the "Kruithof
Curve."  As the light level becomes lower, we see warmer light as
neutral.  A higher temperature light will be seen as cool.
See http://en.wikipedia.org/wiki/Kruithof_curve
Halogens are becoming too ineffient to be used.  We're going to
replace ours with the best CF floods or spots we can find.  There are
a few that advertise rather high CRIs, and, frankly, the artists in
Gallery Los Olivos seem to be happy with even the Home Depot (est.
cri = 82) samples I've installed for testing.
One advantage of the CF flood is that they come in varying color
temperatures.  Because we'll have multiple floods per area, the
artists will be able to control their own color temperature by
swapping out, for example, some cool ones for some warm ones.
2008-12-28 by Andrew Darlow
Hi Paul:
There also exist LED flood lights and LED MR16's, but I haven't used
either.
Buylighting.com has a number of them.
and here is another page full of them:
http://www.besthomeledlighting.com/led_floodlight
I'd be interested in hearing what others have to say about them. They
tend to be very cool, but they may be cool enough to be filtered with
a gel.
All the best,
Andrew
> least 80, I'm told.
> >... I have installed the 5000� K tubes ...
> > that are around 3800�K.
> Paul
> www.PaulRoark.com
Andrew Darlow
www.inkjettips.com
2008-12-28 by pr_roark
Andrew Darlow <ad@...> wrote:
> There also exist LED flood lights and LED MR16's,...
I think the LEDs are clearly the future, but I'm not sure what the
light quality (CRI) is or whether there are appropriate sizes/lumens
for our replacement project.  Actually, there is a program in
California that is going to end up giving our gallery free lights.
So we have to pick from what they have, which seems to be simply a
selection of CF floods and 'spots' (more like floods than a halogen
spot).
I, too, would like to hear if anyone has experience with the LEDs.
2008-12-28 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
There is a company, TCP that makes Compact Florescents in a number of colors.  The have a
280 series that contains a group of bulbs with a FS (Full Spectrum) suffix.  They are 5500k
with a CRI of 90.
I found their 5100K bulbs at a commercial lighting center.  The FS series may have to be
special ordered.  I remember the 5100 bulbs as being priced reasonably.  I'm not sure about
the FS bulbs.
2008-12-28 by Ernst Dinkla
> spot).
> Paul
> www.PaulRoark.com
Over time I have checked the specs of LED lamps at this
Dutch site
http://www.olino.org/
which has a more recent version in English
http://www.olino.org/us/
That may not have all data that is available on the Dutch site.
The CRI on itself doesn't tell all, check the red and blue
samples of the specs here and that's with a total CRI of 87:
http://www.olino.org/us/articles/2008/10/05/edison-led-3%C3%971-w-gu10-ww
None of the LED sources has the light quality of the best
"full spectrum" fluorescents and the last do not meet the
quality of the Solux halogens.
A friend who will shortly occupy another studio intends to
install LED tubes there. I have warned him that the LEDS are
not yet at the quality he needs. The economy of LED lamps
compared to fluorescent tubes isn't better either. The pros
of LEDs are the fast switching possible, working in any
temperature, faster on maximum output after switching on,
much longer life, less environmental waste than
fluorescents, economy if compared to lamps in general. Their
spotlight characteristic is sometimes an advantage but not
always.
LEDs make new armature designs possible:
http://www.lighting.philips.com/in_en/applications/office/daywave.php?main=gb_en&parent=1&id=in_en_applications&lang=en
The manufacturers face the fact that consumers will buy a
LED lamp and never return to replace that lamp so
integrating the LEDS as much as possible in the luminaire is
one way to let the customer return. If the design starts to
become old fashioned the LEDS go with it.
Right now I'm replacing outdoor lamps, non color critical
lamps etc with LED alternatives. I expect that the 12V
halogen armatures with Solux type lamps are best right now
for the studio and that in time better LED lamps that fit
the same GU 5.3 armatures will become available. The larger
part of my shop where the silkscreen printer etc is has
about 25 Philips 950 fluorescent tubes. If possible I would
like to exchange them with LED armature designs when their
light quality becomes better and then use more autoswitching
control to reduce energy waste.
Compact fluorescents like Truelight are an alternative but
not equal in output to Solux.
|             ( unvollendet )            |
2008-12-31 by Ernst Dinkla
> spot).
> Paul
> www.PaulRoark.com
Paul,
Video and camcorder users need small floods and spots with
continuous output. It looks like they embrace LED lighting
faster, armatures that have all LED types included like Red,
Green, Blue, Amber, White, etc to get more full spectrum. I
have not seen a spectral curve yet nor a decent CRI quote
for them. I suspect still an (expensive) compromise on color
quality.
http://www.s131567196.onlinehome.us/
http://www.elementlabs.com/KelvinTILE.html
|             ( unvollendet )            |
2009-01-01 by dlruckus
I can't speak for hi output very broad spectrum led lighting but I can
say a bit for generic LEDs.
I have an ongoing project of a diy XYspectro utilizing LEDs(silly I
know but interesting and educational). In any event, in the course of
designing this, I've had reason to measure and evaluate a fair number
of off the shelf LEDs. In general I found that it would be very
difficult to come up with a set that could be reasonably considered to
approximate any normal lighting's full spectral curve. I was able to
construct full spectrum coverage(roughly 340-750nm) but it has a lot
of spikes in output. That isn't a major issue for my use as it can be
accounted for in calculations but I suspect(as you have mentioned
Ernst) that it would be very expensive to individually control gangs
of relatively narrow peak LEDs in a manner that emulates something
like a continuous spectrum incandescent for large scale viewing
purposes. It took 13 LED bands for me to be comfortable with what I
considered adequate output for reasonable precision of results.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> > spot).
> > Paul
> > www.PaulRoark.com
> Paul,
> quality.
> |             ( unvollendet )            |
2009-01-01 by rternbach
I apologize if this has already been discussed, but I remeber
hearing a professional printer say that when he has an exhibition he
supplies one 4700K bulb per print as this is the light he uses when
doing in his studio while printing and wiewing. (He always expects
his bulbs to be returned after a show). How this would be
accomplished with LED lighting is a question I will leave to the
experts.
Warm Wishes for a Healthy and Prosperous 2009!
Rudy
So.Hadley, Masstts
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
can
of
number
considered to
to
lot
be
gangs
> Regards,
> Duane
> <edinkla@> wrote:
sizes/lumens
lights.
simply a
halogen
> > > spot).
LEDs.
> > > Paul
> > > www.PaulRoark.com
> > Paul,
> > quality.
> > |             ( unvollendet )            |
