LCD Monitor Calibration - OT
2009-01-03 by andre1moreau
Hello,
After calibrating two Samsung monitors, one 22" and one 30" with
GretagMacbeth Eye-One Match 3, I've noticed that when displaying a 21
Grayscale Stepwedge, there are still traces of red in a some of the
wedges.
Another run at calibration was undertaken with BasICColor trial
software. Same results with the stepwedges.
Is this something expected of LCD monitors, or is there something I'm
missing?
TIA,
Andre
Re: LCD Monitor Calibration - OT
2009-01-04 by Jon Cone
Andre,
This parallels a discussion in progress on the Piezography list. What
you did when calibrating your two LCDs was not to calibrate your two
LCDs but to calibrate the video board of your computer because that is
what EyeOne and CV Spyder, etc do. Your video board when it is not
calibrated has the ability to output 256red x 256green x 256 blue
output levels to produce 16.7 million colors. In order to render
grayscale without banding you need all those levels...
What calibration does is to reduce the output levels of the video
board in order to realize the targets of color temperature,
brightness, etc... and saves this as a vLUT which loads when you
startup your computer. Think of the vLUT as three curves being applied
to your video board...
Calibrator displays like the Eizo CG series have an on-board hardware
engine that produces billions of colors. The video board is left at 8
bit (16.7 million colors), and the calibration procedure tunes the
actual engine to select the most appropriate 16.7 million display
colors. Of course this display has an additional cable running to the
computer and when the EyeOne instrument or CV instrument is measuring,
the Eizo software is adjusting the hardware engine of the display. The
video cable and this additional cable are forming a loop. And this is
why calibrator reference displays which calibrate in hardware rather
than software can display amazingly good grayscales. The Sony Artisan
was THE example of a calibrator display. The Eizo CG series advertises
itself to have nearly the same capability.
If you can intervene in the Expert or Advance mode of the EyeOne and
use the Samsung manual controls (if they exist) to dial in the target
color temp, brightness and contrast, you may have a better chance of
having the EyeOne Match produce a less evasive vLUT on your video
board. The idea being here not to just let EyeOne measure your native
temp and brightness, etc but to select the manual portions of Match to
dial in these by hand.
Earlier versions of the software allowed this. I am hopeful yours
still does. I can't check as I only use Artisans. But launch and see
if there is an Expert Mode or a mode which allows you to use the
display controls to dial in to the target. CM used to have a setup
which alerted you when the target was reached. Color Temp is very
critical here as the vLut just yanks down the output of 1 or more
channels in order to get there... it clips.  :(
Prove it! a very old monitor calibration system used to display the
vLUT simultaneously...  was magic in allowing the user to try and
leave it as intact as possible. Its discontinued but there must be
software out there that you can use with the EyeOne that really allows
you to do as much as possible on your own. Of course your Samsungs
have to give you access to their engine in some way or the whole point
is moot.
Hope this helps,
Jon Cone
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "andre1moreau"
<andre1moreau@...> wrote:
> Hello,
> wedges.
> missing?
> TIA,
> Andre
Re: [Digital BW] Re: LCD Monitor Calibration - OT
2009-01-04 by cdtobie
___
Hi Jon,
Well, its one part of what they do... They start by doing any possible
hardware calibration at the display, then move on the VLUT
adjustments, and of course create a profile defining the result when
they are done.
___
Raw color, maximum number of values, but uncorrected... like printing
without color management...
In order to render
___
In order to get nice smooth grays on screen, you should certainly
minimize the adjustments you make at the videocard level... none of
this effects the print, only the screen view, but its nice to not have
excessive banding on screen, as it interferes with seeing your
image...
brightness, etc...
___
No, first it does any adjustment that is possible at the hardware
controls level, which is certainly how "brightness" is adjusted in
virtually all cases. Color temp adjustment, for displays have RGB
Gains controls, are also done at the display hardware control level.
If Gains are not available, and you do not choose Native as your
whitepoint, and you do not have a display with LUT capabilities in the
display, then yes, the final choice is that the VLUTs in the videocard
are adjusted for this, as is gray balance.
___
Which is why users are instructed to set the Whitepoint and Gamma at
the display LUT level on such high end graphics displays first, in
advance of running third party display calibration software; or to use
software that does both. This could mean running a display
manufacturer's software once, to generally define gamma and
whitepoint, then running a third party product such as Spyder3Elite
every few weeks, on the high end graphics display and your other
displays as well (the specialty software for such displays does not
typically play well with other displays or calibrated multiple display
setups). Or it might mean simply running the manufacturer's display
software once in a while, if your needs are simpler. Or it might mean
using a specialty product such as ColorEyes to control the internal
LUTs on the display, as well as doing your general profiling of all
displays.
The order of priority that calibration products use is: set display
hardware controls to optimal adjustments first (where available), set
display LUTs to any further corrections next, (if available), set
videocard LUTs to any remaining needed corrections, and finally,
define the end result in an ICC profile. Displays not having hardware
controls or internal LUTs should be targeted to Whitepoint and Gamma
values reasonably close to their native values, to avoid visible
banding caused by moving them too far with videocard VLUT corrections.
Those with such controls can afford to be adjusted somewhat somewhat
more widely. The new Apple 24 inch LED Cinema Display, for instance,
has neither hardware controls (beyond backlight control for
brightness) nor internal LUTs; but since its native gamma and
whitepoint are close to desired values, it calibrates nicely without
them, and at a price below displays with internal LUTs.
Once videocards and OSes have a functioning high bit pathway from the
card to the display, this will all become moot, and the desirable
features of internal LUTs will be equally functional at the videocard
LUTs, ending the whole problem of proprietary access to internal LUTs
and the communication issues that ensue, and eliminating most needs
for displays with internal LUTs.
Please feel free to repost to your other list...
C. David Tobie
WW Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/spyder3
Well Andre,
This begs the question of you...
Did you, or if you did, were you successful in setting the temperature
and brightness, etc using your display's settings controls?  Did you
get some software feedback or simply click on the available preset
temperature etc in the Samsung?
We have a lot of displays in our classroom and some have pre-sets
which are wicked off from what the pre-set infers. Did you actually
tweak the color and brightness, ?? Or do you have a vLUT which
maaaaaaay be interfering?
I guess David is pointing out that you have a responsibility to set
all these settings in order for the calibration software to do what it
is supposed to do to be less evasive and that is part of their
instruction set now.
What do you think?
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, cdtobie
> ___
> Hi Jon,
> they are done.
> ___
> In order to render
> ___
> image...
> brightness, etc...
> ___
> ___
> displays.
> C. David Tobie
> Datacolor
> CDTobie@...
Re: [Digital BW] LCD Monitor Calibration - OT
wedges.
missing?
___
You are using the same device both times. What it thinks is neutral is consistent both times. What another device would think is neutral might well be a bit different.
C. David Tobie
Datacolor
CDTobie@...
> ___
David,
Are you saying that Andre can not calibrate the displays he owns to
neutral?  Is "it" the samsung or is "it" the colorimeter?
It really depends upon what the meaning of "it" is doesn't it?
Jon
2009-01-04 by Cdtobie
The same calibrator is being used with two different software packages
to calibrate the same display. It produces rhe same gray balance both
times. That implies that it's the calibrator causing the "flavoring"
of the grays. If he now uses the same software, with a different brand
of calibrator, I suspect he will get a somewhat different gray
balance. This can actually be done, by borrowing a Spyder3, and
running it with ColorEyes.
C. D. Tobie
WW Product Technology Mngr.
DataColor.com
CDTobie@...
>> ___
> David,
> Jon
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in
> the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNE
> R” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DA
> MAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE L
> OSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW,
> THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH D
> AMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIG
> ITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTER
> ATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF
> ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) AN
> Y OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
I'm not simply saying the end user must do these things in the right
order; I'm explaining that the software will run you through doing
most of them in the correct order, as part of the calibration/
profiling process.
C. D. Tobie
DataColor.com
CDTobie@...
On Jan 4, 2009, at 12:59 PM, "Jon Cone" <jon@...> wrote:
> Well Andre,
> What do you think?
> Jon
>> is
>> ___
>> Hi Jon,
>> possible
>> they are done.
>> ___
>> In order to render
>> ___
>> have
>> image...
>> brightness, etc...
>> ___
>> the
>> videocard
>> applied
>> ___
>> use
>> display
>> displays.
>> corrections.
>> C. David Tobie
>> Datacolor
>> CDTobie@...
> this same page.
> to keep them short.
> the Files section:
2009-01-05 by andre1moreau
Thanks to Jon and C.David for their replies.
I'll try to provide more information that I hope can shed more light
unto the observation of traces of color appearing when displaying  a
grayscale 21 stepwedge on both Samsung LCD monitors.
The Samsung monitors (22" and 30") are connected to different WinTel
machines.
Brightness and contrast adjustments were done during the calibration
procedure with the software at hand.
With both monitors, the color temperature was at 6600K before
calibration and it was adjusted for a target of 6500K
Further verification shows that basICColor did not produce the same
results as the Match v3 on the 22" LCD monitor. The 21 stepwedge shows
some traces of blue in the highlights with the BasICColor.
On the 30" monitor, there are no visible differences in the generated
profiles by both software.
Andre
2009-01-05 by Louis Dina
Andre:
If you have a Samsung Synchmaster, adjustments made to color,
contrast, gamma and everything else using the controls on the monitor
itself (except the intensity of the backlight, which is the only
analog adjustment) are written to the video card anyway.  If you are
hooked up to the monitor through a digital connection, you will
generally get better results.  My 24" Synchmaster is hooked up to a
Matrox Parhelia video card, and during calibration, ALL monitor
controls are disabled, except the intensity of the backlight.  All
adjustments will be written to the video card anyway, so it is a moot
point.
If you hook your LCD up to an analog connection, you will be able to
adjust color, contrast, gamma, etc using the monitor controls, but
again, they are written to the video card anyway.  I have a second
Synchmaster monitor hooked up to the analog port, so I can adjust it
independently (my video card does not have two independent VLUTs).  I
just use it for palettes anyway, so it doesn't have to be perfect.
Even on my large monitor (hooked up to the digital port) my grayscale
is not perfect, but it is mighty close.  Probably has to do with 8 bit
rounding error and limitations of the software.  Simple curves are
used to correct the colors in your video card's VLUT, so not all of
points will be perfectly neutral.
If you want to approach perfection, be prepared to spend money for a
monitor that has adjustments that can be made independent of the video
card (like a high end Eizo).
Frankly, I don't really sweat it even if my grayscale is not perfect.
 It may be noticeable when dealing with computer generated grayscale
ramps, but rarely noticeable in a continuous tone image.  When I have
a critical gray (and am working in RGB) I just use the info palette to
make sure my tones are neutral.
Hope this helps.
Lou
> machines.
> Regards,
> Andre
