Richard,
I destroyed a 7K series printer loaded with Lyson quad inks when I
switched to Cone Quads. They are super not compatible. When they hit
pigments it becomes "Lyson Jelly". Not cool. Not good at all!
What I would recommend is buying the Cone flush fluid which is the
most effective cleansing fluid I've ever used. Then do about 3
initial fills with it in there. This stuff really cleans the system
out. After that I would also consider changing the dampers if you can
still buy them, and print out a few flush grayscale charts available
on Piezo website, making sure all this pinkish flush fluid has
completely cleaned the system before putting anything in behind those
nasty Lyson dyes.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard
Smallfield <r.smallfield@...> wrote:
> Hi,
> I'm considering buying a second-hand printer that currently has a
Lyson CIS - I do know that flushing is necessary if I want to use
(eg) Cone inks after Lyson, but I wondered if it is possible to flush
the Lyson CIS somehow, so I could then use it for Cone or MIS inks?
> (PS - I understand Lyson are dye as opposed to pigment and have
inferior fade resistance, correct?)
> thanks,
> Richard
> www.richardsmallfield.com
> "You should never use the phrase 'you should'."
> -- Tim Veatch
