A "solarized" appearance ?
2009-01-28 by frankg_photo
I just printed with QTR, 2200, UC on GoldFibreSilk and although the
print is pretty good (I'll reserve judgement until the morning when
it's dry), I did notice that when I angle the print to the light
source,  it has a "solarized" appearance. I don't know if it's
characteristic of the paper, or ink, or curves. I don't quite know how
to explain it, and it would be impossible to post a jpeg showing it.
Do you know how I can correct this ?
Thank you,
Frank
Re: A "solarized" appearance ?
2009-01-28 by hp9180profile
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo"
> Thank you,
> Frank
By solarized do you mean a bronze-metallic sheen to the image when held
at an angle to the light? If so that is called bronzing and is an
inherent feature of the Epson k2 inks on gloss and semi gloss paper.
Some of the oversprays may help as does a coat of GLOP or just use
matte papers on which it does not show up.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hp9180profile"
> > Thank you,
> > Frank
Yes, I suppose it could be described as metallic. I don't see a bronze
tone & don't know if it's what you call 'bronzing' or not ?
It is most evident at the edges where dark & light tones meet.
You say that it is inherent with this printer/inkset (photo black &
light black) & all gloss/semi-gloss papers ?
What oversprays are recommended ?
thanks,
Frank
know how
> > > Thank you,
> > > Frank
held
I should add that although you say I will get this from Any gloss or
semi-gloss paper, I haven't noticed it before. I have printed on Epson
Premium Gloss and Ilford Pearl
> thanks,
> Frank
Well, I use MIS GlOP to overspray PK papers. If you have a spare slot
you could install this in your 2200. It does a great job in my view of
getting rid of bronzing. Some on this board use Premier Art Shield but
I have no first hand knowledge of this product so would not like to
comment on its effectiveness at removing bronzing.
It will be there, just not so noticeable on those papers. Epson papers
in particular seem to control it better. Regardless, I have bronzing on
every 2200 print I ever made using the Epson inks, to a greater or
lesser extent. You have to look for it though, and most people viewing
your work will be looking at the image, not the bronzing.
2009-01-28 by jlk4410
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hp9180profile" <owens@...>
> > thanks,
> > Frank
 Three light coats of PremierArt Print Shield on my IGFS prints does an excellent job of
knocking down any metamerism or 'bronzing'. I'm using QTR with my R2400 & K3 inks and
I'm very happy with Gold Fibre Silk.
Good Luck!
Julian Kaiser
an excellent job of
R2400 & K3 inks and
> Good Luck!
> Julian Kaiser
Julian,
You get this effect with K3 inks too? I thought it was supposed to be
a K2 ink + gloss/semi-gloss paper problem ?
2009-01-28 by Louis Dina
I'm no ink expert, but I have read that pigment inks are more
suseptible to bronzing and metamerism than dye inks, partly due to
their larger particle sizes.  I know some inksets and ink colors
exhibit this more than others.  Yellow inks seem to have more of their
share of problems than some of the others.
I'm currently using a Canon iPF6100 pigment inkjet printer, and like
Epsons, it too can exhibit some bronzing, gloss differential and
metamerism, which is much more noticeable on some papers than others.
 As usual, luster, silk and gloss papers tend to be the worst.
Different lighting can also either help hide or accentuate it.
When mounted behind glass or Plexi, much or all of this effect is
invisible to my eye.  Sprays are another option.
Lou
RE: [Digital BW] Re: A "solarized" appearance ?
2009-01-28 by David Whistance
It is noticeable with UC K3 inks if you look for it, albeit very much less
than with the previous UC K2 inks.  I think the only way to avoid it is to
use GLOP like the Z3100.  Sadly, at least in my experience, it is rather
harder to get the GLOP laid down correctly than it seems at first glance.
Whilst you get rid of the bronzing/gloss differential you start to suffer
other problems like fine mottling in the upper midtones which is equally if
not more objectionable.  Just goes to show what a good job HP have done with
the Z3100.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of
frankg_photo
  Sent: 28 January 2009 19:04
  Subject: [Digital BW] Re: A "solarized" appearance ?
  an excellent job of
  R2400 & K3 inks and
  > Good Luck!
  > Julian Kaiser
  Julian,
Re: [Digital BW] Re: A "solarized" appearance ?
2009-01-28 by CorrPro96@aol.com
In a message dated 1/28/2009 3:18:29 P.M. Eastern Standard Time,
david.whistance@... writes:
the Z3100.
David  Whistance
David:
In your experience, has HP solved the gloss differential problem, or is
there still "fine mottling in the upper midtones"?
Richard
_www.rmassiephotography.com_ (http://www.rmassiephotography.com)
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100000075x1215855013x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=De
cemailfooterNO62)
> the Z3100.
I am starting to collect info on printers that will inform my next
purchase when I manage to upgrade from the 2200 - I hadn't really
thought of anything other than an Epson, but now that you mention th
HP Z3100 I am curious - do they eliminate this problem entirely ?
2009-01-29 by jlk4410
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" <frankgross@...>
> an excellent job of
> R2400 & K3 inks and
> > Good Luck!
> > Julian Kaiser
> Julian,
Yes, very, very slightly and not on all images. Since I am printing a portfolio that will be
handled,(loose prints in a clamshell case protected with archival sleeves) and the prints
may be viewed from many angles I'm using Print Shield as a final step.
Julian Kaiser
2009-01-30 by Clayton Price
This is a little late for this thread, but when I first read it, I
was wondering why
one should have to spray a print three times to eliminate bronzing or
metamerism.
I've not used Gold Fibre Silk paper, but assume it's at least close
to a glossy paper.
For whatever it's worth, even though most of this group talks about
various ink mixtures and
how they work with different papers, for my purposes, there's been a
very easy solution to
eliminate both the metamerism and bronzing on glossy paper. I print
my commercial work
mostly on a 2400, using Ultrachrome K3 Inks. I tested 5 or 6 papers a
couple years ago, and
found that Lumijet Glossy II works perfectly, with the downloaded
profile from Hahnemuhle,
who bought the company a few years ago.
The one thing I dislike about the paper is that it's not [paper]! It
looks like an RC paper - I'm not
sure of it's exact composition, and probably would not generally pick
it for prints in a show. On
the other hand, I'm able to make perfect reproductions of Old
Master's paintings, which is difficult
to accomplish under most conditions. This has been true, even for the
very large prints which I send
out for printing, from my files. The lab uses the same paper. Really
- accurate reproduction under
3200 Kelvin gallery lighting and daylight, even when mixed with
fluorescent.
Epson really did something correctly with that ink set.
Clay Price
 > an excellent job of
 > R2400 & K3 inks and
2009-01-31 by frankg_photo
why
> metamerism.
Clay,
I'm the original poster so I'm obviously looking for solutions rather
than being able to dish out advice. But what I've learned so far is
that the Photo Black ink (in particular) sits on the surface and has a
different reflectance to the paper surface and that causes the
'solarized" appearance particularly where the dark and medium or light
tones meet.
Frank
>  why
or
> > metamerism.
> Clay,
> tones meet.
> Frank
& (I should have added to the last post) by spraying the 'shield' 2 or
3 times, you add some gloss to the print thereby lessening the
difference between the reflectance of the blacks and the rest,
reducing the 'solarized" appearance.
2009-02-01 by Clayton Price
Hi Frank,
I guess my point  (although I didn't say it in exact terms), is that
different papers
behave in different ways. Some, I remember from the early days with
Piezo inks,
all sat right on the surface of glossy papers -- so much so that you
could wipe half
the inks off with a paper towel, hours later.
The paper I mentioned, Lumijet Gloss II, ( I'm not connected with
them in any way) pulls the K3
Photo Black deep enough below the surface so that I'm not seeing any
of the  reflectance differential from the surface,
even with top back lighting. Until I found that paper, I totally
avoided glossy papers, because IMO, it's a pain
in the rear  to start spraying, not to mention a myriad of
environmental problems with sprays and their
various compounds, and the need for a ventilated spraying booth if
one does spray!
Clay
   >....what I've learned so far is
has a
light
 > tones meet.
 > Frank
2009-02-02 by frankg_photo
Hi Clay,
Thanks for the tip on which gloss paper doesn't require spraying.
I had originally encountered this problem by choosing a highly
recommended paper (Ilford Gold Fibre Silk). I am using K2 ink (2200)
which is probably a lot worse than your K3 and may even be a problem
on the Lumijet paper too? As recommended by others here, I bought a
can of PremierArt Shield spray and just tried it out on two small
prints - I am amazed at the improvement. But I do agree with you that
it's a pain to have to use spray.
Frank
> Hi Frank,
> different papers
> Piezo inks,
> could wipe half
> one does spray!
> Clay
> has a
> light
>  > tones meet.
>  > Frank
2009-02-02 by Clayton Price
Frank - I don't remember if I tried glossy with K2 inks, although I used
them for beta testing the 2200 Epson. When the 2400 came along,
I switched the 2200 to Piezo inks and still use them, when the printer
isn't clogged. BTW, the 2400 has never clogged, even once, in the
three years I've been using it. I don't know whether to thank the
printer
or the K3 inks for this occurrence, but whichever, it's been the best
behaving printer I've used in the last ten years.
Posted by: "frankg_photo" frankgross@...   frankg_photo
Sun Feb 1, 2009 4:59 pm (PST)
