Does QuadtoneRIP Have A Command Line Options?
2009-04-30 by ric_kb
is there a set of CL options that can be issued to qrip? specific search is for one that would exercise the nozzles of the printer through a step wedge of tones...
TIA
Richard
Re: [Digital BW] Does QuadtoneRIP Have A Command Line Options?
2009-04-30 by John Labovitz
[I only know about the Mac version, so that's what I'm talking about
here.]
Not as far as I know of.  QTR does have a set of command-line tools,
but they are strictly for generating profiles.  All interaction with a
printer is through sending an image through the print system, along
with parameters specifying any settings (as found in the usual Print
dialog box).
I suppose you could create a command-line tool that would generate an
image file with a series of tones for each ink, and send it through
the print system in Calibration mode.  (If you want the details on how
you'd create that file, specifically the RGB values to get particular
values of particular inks, let me know.)
There also might be a way to communicate directly with the underlying
CUPS printing system, but you'd probably be re-doing a lot of the work
that Roy's done, so that might not be efficient.
I'm curious: Why do you want to use a command-line tool?  Are you
looking to print a pattern periodically to keep the nozzles clear?
--John
Re:Re: Does QuadtoneRIP Have A Command Line Options?
2009-05-01 by ric kb
thanks John, that was as I thought...
My question(s) of the past week on several of the BW+Print+digitalPhoto+etc lists have been to gain insight over the build-or-not question I have.
The answers indicate that I will have to build the system, even if it means duplicating some of what others have already done...
>>are you looking to print a pattern periodically to keep the nozzles clear?
-- No, not a nozzle  clean, but that is certainly a nice addition :)
/Richard L.
here.]
dialog box).
--John
