new user frustration epson 2400 problems
2009-05-08 by shudaizi
I hope this is not too basic of an issue for this group, which from the threads has an extremely high degree of expertise and a lot of experience with digital printing, but I'm quite frustrated and numerous readings of the Epson user guide and google searches have failed to get me off the ground here. So, in semi-desperation ... Preliminary tech info: Printer: R2400 OS: Mac OS X 10.5 Photoshop CS3 Most recent Epson drivers I have gotten this combination to print on EEM, for proofing my photos (in quarter (4.25" x 5x5" in) and full letter size), just fine and the prints look good. So good, in fact, that I would really like to try using some other papers... My problem is that I cannot for the life of me find the correct combination of ink, paper feed method, and print settings, to print on Innova Soft Texture Art. I have downloaded the Innova ICC guide for the R2400, which lists the MK ink and a paper setting of "Matte paper -- heavyweight". But the list of papers I can choose in Photoshop (print settings) does not list a heavyweight matte, and I've tried all the other matte papers with all the different feed methods (top, back, front) and I either get an error message or the paper misfeeds or both. If I try loading the paper in the sheet feeder, then the printer status app gives me a message saying "media is empty or not loaded correctly", usually after feeding the sheet completely through the machine and out the front, though this doesn't happen every time; front loading pulls the paper in part way and then it misfeeds (goes askew) and it spits it back out; rear loading pulls the paper part way in and then it sticks with another error message. I've tried switching inks to the PK cartridge, but that really changes nothing since I can't get the paper to load properly at all no matter which paper I choose. Am I missing something really basic here? Or is there something malfunctioning with the feed system? (It is a used printer, so that's always a possibility in the back of my mind.) Thanks in advance for any suggestions ... Kevin Landdeck www.flickr.com/photos/shudaizi/
