> Complain to Harmon, I did about the rolls and they pretended it was
> not an issue. Maybe the more they hear about it the better.
> Mark
> http://www.stillrivereditions.com
> On Jun 23, 2009, at 2:27 AM, Doug Fisher wrote:
> > I would appreciate any thoughts on methods to remove the slight curl
> > at the
> > edges of Harman Gloss FB Al before putting it in the printer. I
> > have been
> > doing some printing for the first time in a while with my R2400 and
> > one
> > thing that has changed is that the humidity level is quite a bit
> > higher
> > (Atlanta finally had a wet spring and the multi-year drought has been
> > broken).
> > The higher humidity (about 45% in the air-conditioned room with the
> > printer)
> > has caused the Harman paper to curl at the edges on all four sides
> > (both old
> > stock and freshly opened stock). The curl along the edge is pretty
> > small in
> > width but fairly pronounced. It is just enough that I am getting head
> > strikes at one of the very top corners at the start of the printed
> > page
> > (along the side) and sometimes at the very bottom of the page at one
> > corner
> > (also along the sides). I left the paper out over night see if it
> > would
> > flatten any after acclimating to the room but I didn't have any
> > luck. The
> > platen is set for thin papers.
> > Any advice on what to do or not to do to remove the curl without
> > damaging
> > the coating on the surface of the paper would be appreciated. If it
> > were a
> > large gentle curve all the way across the paper, a reverse roll would
> > probably do the trick. Since the curl is just at the edges and the
> > coated
> > surface is pretty delicate, I have been trying to bend it flat just
> > using a
> > cotton gloved hand. Hopefully someone has a better method!
> > Thanks in advance,
> > Doug
> > BetterScanning.com - Innovative Accessories for Better Film Scanning
> > http://www.BetterScanning.com/
> > Please visit the Group Homepage to check the Files, and other
> > resources as they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you wish
> > to unsubscribe, please edit your Membership preferences by visiting
> > this same page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier messages
> > to keep them short.
> > - Good manners are required at all time. No personal attacks or
> > flames. Hostile, aggressive or argumentative users may be removed
> > from the membership without notice.
> > - Keep your posts and threads related to the group topic of digital
> > B&W printing. Users who persistently make off-topic posts may be
> > removed from the membership.
> > - By posting on this forum you agree to abide by the group rules and
> > guidelines, and to abide by the actions and decisions of the group
> > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> > Files section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> > LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE
> > PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
> > DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP;
> > OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
> > GROUP.
> > Yahoo! Groups Links
