So the problem is that you never know if the restore of your system disk
will work unless you actually try and successfully do it.
If you have a spare disk I would back up your system disk - replace it with
the spare one and try and restore to it.
Most restore software is a bit picky on PC as to exactly your hardware
config (because there are so many), without doing a restore you'll never
know if your system backup is useful or just a waste of time.
If you don't have a spare disk you can still do a dummy system disk
(partition) restore and take the process all the way until it actually
starts to do the restore. At least that way you'll have a pretty good idea
if your restore software can work with your hardware config (mainly the
problem is hard disk controller /motherboard support).
Personally I use Acronis and it has some quirks, but I found a build that
works with my config and I can be back up and running in 30 - 60mins from a
system disk crash.
Mike
2009/7/5 ann clancy <jaclancy1937@...>
> thanks,
> i will check them out. i was't necessary looking for free, just good and
> simple for a non-computer person.
> ann
> --- On Sun, 7/5/09, Greg <dfaprinting@... <dfaprinting%40yahoo.com>>
> wrote:
> From: Greg <dfaprinting@... <dfaprinting%40yahoo.com>>
> Subject: [Digital BW] Re: Moving PS
> To: DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>
> Date: Sunday, July 5, 2009, 2:16 PM
> --- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "Greg"
> <dfaprinting@ ...> wrote:
> > Also maybe this which is open sourced and free.
> Sorry, forgot the link: http://g4l.sourcefo rge.net/
