Help! Scanning B&W negs
2009-07-31 by Walter Oliver
I have an Epson 4990 flatbed scanner which includes a frame for strips of negatives.
I want to scan the negs to at least make decent proof sheets, but my first attempt was absolutely horrible.
Using color produced scans with a heavy blue tint, and using 16 bit gray scale gave me very flat, dull gray scans with a Dot Gain 20% embedded profile.
I used Professional mode, B&W negatives, and changed no other settings except the 16 bit gray scale.
Can anyone point me in the right direction to get decent scans from chromagenic B&W film (Ilford XP-2 or Kodak BW400CN)?
Thanks in advance,
Walter
Re: [Digital BW] Help! Scanning B&W negs
2009-07-31 by renato cury
Hello Walter,
      When you bought your scanner it came with a SilverFast Disc ( probably Ai version) , two IT-8 targets ( one 4x5 transparency and one 5x7 reflective) and  a Monaco Easy program.       Install and use Silver Fast instead of Epson Scanner Driver if you are not already doing so.   What follows is my way of using it for BW negatives, chromogenic or not:
      -Use HDR (16 bits per channel ) . There is a box of configurations where you will find an option for defining HDR gamma. Try gamma 2.2 for HDR.        HDR will permit you to scan only as a RGB positive and does not leave you  apply any correction nor unsharp mask, etc. You will get a very flat negative image.       -Define scan resolution numbers at 100% . Avoid " broken numbers" . Find  the one that gives you the nearest file size of our interest among 1200, 2400, 3200 or 4800 ( the maximum for your scanner ).         -Open it in Photoshop. Ignore or accept the embeded profile from Silver Fast, but dont convert it to any RGB that has a gamma diferent from the one you are thinking to use when editing your grayscales . ( Prophoto, for instance has a gamma 1.8, Adobe 98 has a gamma 2.2 ). I supose that your color settings in PS are configured to preserve profiles when opening and to ask when finding an embeded profile different
 from the one you have choosen for RGB color space.        -Look at the image at 100% or more (200%, 400%) and choose the best channel in terms of sharpness( in my 4990 is the green channel and in my V750 is the blue ). Select the best channel and convert it to gray gamma 2.2 ( 16 bits). Take a look at the histograms of each channel too and check if the channel you`ve choosen is not clipped .      -Invert the image. Go to adjustment layers/curves and adjust for what you want.
   If your negatives are very similar one to each other you may use a set of all these actions but still can adjust the adjustment layer for each case.
     Apply un-sharp mask (s)  after defining the print size.          Renato
--- Em sex, 31/7/09, Walter Oliver <wso@...> escreveu:
De: Walter Oliver <wso@...>
Assunto: [Digital BW] Help! Scanning B&W negs
Para: DigitalBlackandWhiteThePrint@yahoogroups.com
Data: Sexta-feira, 31 de Julho de 2009, 15:07
Thanks in advance,
Walter
Veja quais são os assuntos do momento no Yahoo! +Buscados
http://br.maisbuscados.yahoo.com
2009-07-31 by Mark Savoia
Can somebody explain to me what all the  are in this post?
Mark
http://www.stillrivereditions.com
On Jul 31, 2009, at 6:30 PM, renato cury wrote:
> Hello Walter,
> Â Â  Â  Â When you bought your scanner it came with a SilverFast
> Â  Â  Â Install and use Silver Fast instead of Epson Scanner Driver
> if you are not already doing so. Â  What follows is my way of using
> Â Â  Â  Â -Use HDR (16 bits per channel ) . There is a box of
> Â -Define scan resolution numbers at 100% . Avoid " broken
> scanner ). Â Â Â  Â  Â  -Open it in Photoshop. Ignore or accept the
> and adjust for what you want.Â
> Â Â  If your negatives are very similar one to each other you may
> layer for each case.Â
> Â Â  Â  Apply un-sharp mask (s) Â after defining the print size. Â Â
> Â Â  Â  Â  Renato Â
I can not. Will update my Safari. It' s a shame.
      Renato
--- Em sex, 31/7/09, Mark Savoia <mark@...> escreveu:
De: Mark Savoia <mark@...>
Assunto: Re: [Digital BW] Help! Scanning B&W negs
Data: Sexta-feira, 31 de Julho de 2009, 20:05
Mark
http://www.stillriv ereditions. com
> Hello Walter,
> Â Â  Â  Â  Renato Â
> --- Em sex, 31/7/09, Walter Oliver <wso@comcast. net> escreveu:
I sent my original post to my Gmail box. No problems . Is it an Yahoo issue ?
   Renato
--- Em sex, 31/7/09, renato cury <yrucotaner@yahoo.com> escreveu:
De: renato cury <yrucotaner@...>
Data: Sexta-feira, 31 de Julho de 2009, 20:20
      Renato
--- Em sex, 31/7/09, Mark Savoia <mark@stillriveredit ions.com> escreveu:
De: Mark Savoia <mark@stillriveredit ions.com>
Para: DigitalBlackandWhit eThePrint@ yahoogroups. com
Mark
> Hello Walter,
> Â Â  Â  Â  Renato Â
____________ _________ _________ _________ _________ _________ _
http://br.maisbusca dos.yahoo. com
2009-08-01 by Sam McCandless
I don't know what it is, Renato.
But I don't see any connection between these problems in e-mail text
and the Safari browser. So I would postpone upgrading it for now. Or
changing anything else until you identify the source of this problem.
My guess is that it's a problem with your e-mail software. Notice
below that the same "A" which was inserted before your text in your
post was also inserted before Mark's text in his post. But only in
your software's quote of Mark's post; it was not inserted in the copy
of his post which I got from Yahoo. Neither were the extra line breaks.
Your keyboard occurs to me as another possibility, maybe in
conjunction with your e-mail software.
In any case, I think it is just another computer problem, not "a
shame". We are all victims of it to various degrees, usually in my
experience due to a logical expectation of a machine programmed by
mistake to let us down. And, of course it's embarrassing, but there's
no shame in it. It is however annoying not to know how it happens. So
I hope you will keep us informed. In the meantime, I'm going to think
of the extra "A"s and blank spaces as a bonus. 8)
Sam
> Yahoo issue ?Â
> Â Â  Renato
> --- Em sex, 31/7/09, renato cury <yrucotaner@...> escreveu:
> Â
>       Renato
> escreveu:
> ÂÂ
> Mark
>> Hello Walter,
>> a SilverFast
>> program. Â
>> Scanner Driver
>> using
>> is a box of
>> nor
>> unsharp mask, etc. You will get a very flat negative image. Ãâ
>> €š   Â
>> from the one you have choosen for RGB color space.  Ãâ
>> €š      -Look
>> you may
>> the print size. Â Â
>> Â Â  Â  Â  Renato Â
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE
> PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
> DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP;
> OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
> GROUP.
2009-08-01 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> Mark
Must be NSA flagging of some sort:)  With Safari I see variations of them in emails that I know are composed on non-Qwerty keyboards with both OS X and Windows and I see them browsing with Safari on Windows centric websites.  Maybe something akin to OS X created spaces in file names showing up as % in Windows.
2009-08-01 by renato cury
Dear Sam,
      I hope it will not show in this post I`m writing now.
     I sent, as a test, some e-mails for myself directed to my addresses in Yahoo ( the one I`m using at this moment ) and to my Gmail with the same computer ( Mac G5/OS10.4.11) through Safari, No problems.      I don`t use any e-mail software other than yahoo and gmail ( Outlook, Apple's Mail, etc) so as I can always see my e-mails form any machine, any place.
     Thanks for correcting my words ( my english is very poor ) : It is not a shame but still embarrassing, indeed.
      Renato
--- Em sex, 31/7/09, Sam McCandless <samcc@...> escreveu:
De: Sam McCandless <samcc@...>
Data: Sexta-feira, 31 de Julho de 2009, 21:49
Sam
> Yahoo issue ?Â
> Â Â  Renato
> Â
>       Renato
> escreveu:
> ÂÂ
> Mark
>> Hello Walter,
>> a SilverFast
>> program. Â
>> Scanner Driver
>> using
>> is a box of
>> nor
>> €š   Â
>> €š      -Look
>> you may
>> the print size. Â Â
>> Â Â  Â  Â  Renato Â
> this same page.
> to keep them short.
> Files section:
> GROUP.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
