Postscript Error?
2009-08-15 by shileshjani
Hello All, I wonder if someone can help me. A few days back, I noticed my computer had rebooted after an auto update. It is an Win XP Pro system. When I launched CS3, I noticed that all of my pallets had reverted to default, and my "color managment" polies had also changed. So I reset them to Color:Adobe RGB, Gray: Gamma 2.2, etc. When I tried to print on my 4880, I got a pop-up error, some thing to the effect "....you are trying to print to non-postscript printer, some of the yada yada will not be available..." I hit OK, and the image printed just fine. I tried printing onto my older 4000, and I get the same message. When I checked the "output" section of the print driver, I see that "binary" was selected by default. Just for giggles, I launched Photoshop 7, and found in print dialog "output" that "ascii" was seleced by default. Since my prints from CS3 are just fine using my routine, should I be concerned about fixing this pop-up error, or should I just go ahead and check the "do not show this again" box in the pop-up error? Thank you. Shilesh
