Black areas in Scanned negatives
2009-09-11 by russ.dupont
Sometimes when I scan overexposed negatives there are areas, specifically in the shadow areas that are solid blacks. What can be done to prevent this? I use an Epson Perfection 4490 and scan at 1200 dpi. I've tried scanning at a lower dpi but the results are the same.
2009-09-11 by Gary Weaver
Try scanning as a positive. Remember that the shadow is the clear area of the emulsion. *********** REPLY SEPARATOR ***********
On 9/11/2009 at 5:33 PM russ.dupont wrote: >Sometimes when I scan overexposed negatives there are areas, specifically >in the shadow areas that are solid blacks. What can be done to prevent >this? > >I use an Epson Perfection 4490 and scan at 1200 dpi. I've tried scanning >at a lower dpi but the results are the same. > > > >------------------------------------ > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. >Yahoo! Groups Links > > >
2009-09-11 by pdesmidt tds.net
Scan resolution isn't the problem. You're clipping image data. Check all of your scanner settings to make sure that you clip as little as possible. Sometimes black and white clipping points are expressed as a percentage. Make that number as small as possible. It can also help to include some of the unexposed film area around the image on the negative, since that scanner software will now treat that as image material, and the film base will have less density than any place in the frame that has detail. [Non-text portions of this message have been removed]
2009-09-11 by Russ Dupont
Thanks. I am scanning as a positive. ________________________________
Sent: Friday, September 11, 2009 2:16:20 PM
Subject: Re: [Digital BW] Black areas in Scanned negatives
>this?
>http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt
>page.
>them short.
>the membership.
>and Moderators. See “Group Topic, Rules and Guidelines” in the Files
>section:
>http://groups. yahoo.com/ group/DigitalBla ckandWhiteThePri nt/files/
>YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
>“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>“OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
[Non-text portions of this message have been removed]2009-09-11 by Russ Dupont
Thanks very much. I am including the clear film border in the scan. I'll check the scanner settings. ________________________________
Sent: Friday, September 11, 2009 2:36:09 PM
[Non-text portions of this message have been removed]2009-09-12 by barrysnidow
Agreed. If you're using the Epson drivers, I recommend using the histogram (levels) feature to set your white point and black point. If the new drivers are like the preceding versions, the histogram view is a bit wanky in that you have to click the "preview" (I think that's how it's labeled...) to actually view the histogram setting effects. Also, I would double check all your sharpening, etc. settings. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pdesmidt tds.net" <pdesmidt@...> wrote:
> > Scan resolution isn't the problem. You're clipping image data. Check all > of your scanner settings to make sure that you clip as little as possible. > Sometimes black and white clipping points are expressed as a percentage. > Make that number as small as possible. It can also help to include some of > the unexposed film area around the image on the negative, since that scanner > software will now treat that as image material, and the film base will have > less density than any place in the frame that has detail. > > > [Non-text portions of this message have been removed] >
2009-09-13 by Russ Dupont
Good suggestion. Thanks very much. ________________________________
Sent: Saturday, September 12, 2009 9:07:36 AM
Subject: [Digital BW] Re: Black areas in Scanned negatives
--- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "pdesmidt tds.net" <pdesmidt@.. .> wrote:
