first print with Alise, VERY pleased! (but would like .qidf file if available)
2009-09-16 by paulmwhiting
Hello again, everybody. Well, after considerable roller cleaning I finally got Alise loaded in my R1800 (see earlier post), rear manual feed. I then proceeded to print using QTR but not having the curve for that paper I chose the one I had been using for Premier Art Hot Press 205. It's my first print with this paper (using the 3MK method, btw). Paul has been speaking well of Alise because of its high DMax and I must say I was blown away. It's quite simply the best print I've ever pulled! It's on a sheet of 8 1/2 x 11 Alise, with about a 1/2" border all around, of a downtown (Billings, MT) building for an architect. I took the photo with a Canon Pro-1, in color at full resolution, changed it to black and white using a free Channel Mixer plugin for Photoshop Elements 2.0. That plugin comes with a Curves option as well so I could then tweak the contrast. Haven't tried a 5 x 7 yet, however. Thank you, Paul, for researching and recommending this paper... I'm very pleased. Is there a .qidf file for that paper, with which I could then generate the .quad file? This print looks so good that maybe the Premier Art HP205 curve is satisfactory to use. (I don't know how to make curves... maybe that's my next "learning opportunity" <G>.)
