Epson 7900 support for mac....bah. (mini rant)
2009-11-16 by sagaface
I can't get the latest firmware update - which would stop this thing from cleaning all the time - until next Spring. Or, I can borrow someone else's computer with an older OS version OR a PC, hook up my printer, install the printer utility panel, THEN download the firmware. Otherwise I'm s**t outta luck. um...!! Sarah
2009-11-16 by johnvphoto
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > I can't get the latest firmware update - which would stop this thing from cleaning all the time - until next Spring. Or, I can borrow someone else's computer with an older OS version OR a PC, hook up my printer, install the printer utility panel, THEN download the firmware. Otherwise I'm s**t outta luck. What problem are you having? What OS X are you running?
I'm running the latest version of Snow Leopard....the Epson tech told me I could not update firmware with SL until Spring, which is supposedly going to make the cleaning cycles less aggressive. I have both the Auto Nozzle Check and another nozzle setting I can't remember the exact name of checked off, but it doesn't help. Meanwhile I watch my ink levels go down as cleaning is very frequent. Frustrating. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "johnvphoto" <jvlist@...> wrote:
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@> wrote: > > > > I can't get the latest firmware update - which would stop this thing from cleaning all the time - until next Spring. Or, I can borrow someone else's computer with an older OS version OR a PC, hook up my printer, install the printer utility panel, THEN download the firmware. Otherwise I'm s**t outta luck. > > What problem are you having? What OS X are you running? >
2009-11-16 by Mark Savoia
I have been on the new firmware for about a week, I see no difference in cleaning cycles frequency and as an added bonus it now comes up with an error of "some nozzles may be clogged". I was told by Epson to ignore it, nozzle checks are perfect. Mark http://www.stillrivereditions.com
On Nov 16, 2009, at 3:03 PM, sagaface wrote: > I'm running the latest version of Snow Leopard....the Epson tech > told me I could not update firmware with SL until Spring, which is > supposedly going to make the cleaning cycles less aggressive. I have > both the Auto Nozzle Check and another nozzle setting I can't > remember the exact name of checked off, but it doesn't help. > Meanwhile I watch my ink levels go down as cleaning is very > frequent. Frustrating. >
That's useful information. Thanks, Mark. Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> > I have been on the new firmware for about a week, I see no difference > in cleaning cycles frequency and as an added bonus it now comes up > with an error of "some nozzles may be clogged". I was told by Epson to > ignore it, nozzle checks are perfect. > > Mark > http://www.stillrivereditions.com > > On Nov 16, 2009, at 3:03 PM, sagaface wrote: > > > I'm running the latest version of Snow Leopard....the Epson tech > > told me I could not update firmware with SL until Spring, which is > > supposedly going to make the cleaning cycles less aggressive. I have > > both the Auto Nozzle Check and another nozzle setting I can't > > remember the exact name of checked off, but it doesn't help. > > Meanwhile I watch my ink levels go down as cleaning is very > > frequent. Frustrating. > > >
2009-11-17 by johnvphoto
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > I'm running the latest version of Snow Leopard....the Epson tech told me I could not update firmware with SL until Spring, which is supposedly going to make the cleaning cycles less aggressive. I have both the Auto Nozzle Check and another nozzle setting I can't remember the exact name of checked off, but it doesn't help. Meanwhile I watch my ink levels go down as cleaning is very frequent. Frustrating. Is the problem Epson LFP Remote Panel will not run on SL?
2009-11-18 by Walker Blackwell
Can't you just turn Auto Nozzle check/clean off on the printer? The 11880 lets you do this. You can also set the auto nozzle clean per/5/ print thing to 30 or whatever you need. This should do it. I don't see why you need to update firmware. Walker On Nov 16, 2009, at 8:52 PM, johnvphoto wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" > <sagaface@...> wrote: > > > > I'm running the latest version of Snow Leopard....the Epson tech > told me I could not update firmware with SL until Spring, which is > supposedly going to make the cleaning cycles less aggressive. I have > both the Auto Nozzle Check and another nozzle setting I can't > remember the exact name of checked off, but it doesn't help. > Meanwhile I watch my ink levels go down as cleaning is very > frequent. Frustrating. > > Is the problem Epson LFP Remote Panel will not run on SL? > > > Walker Blackwell 802.821.4451 www.walkerblackwell.com aim: greendirtblues wblackwell@... [Non-text portions of this message have been removed]
2009-11-18 by Mark Savoia
Please tell us where that menu is. My 9900 only shows off or on auto nozzle check. Mark http://www.stillrivereditions.com
On Nov 17, 2009, at 11:11 PM, Walker Blackwell wrote: > Can't you just turn Auto Nozzle check/clean off on the printer? The > 11880 lets you do this. You can also set the auto nozzle clean per/5/ > print thing to 30 or whatever you need. This should do it. I don't see > why you need to update firmware. > > Walker > > On Nov 16, 2009, at 8:52 PM, johnvphoto wrote: > >> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" >> <sagaface@...> wrote: >>> >>> I'm running the latest version of Snow Leopard....the Epson tech >> told me I could not update firmware with SL until Spring, which is >> supposedly going to make the cleaning cycles less aggressive. I have >> both the Auto Nozzle Check and another nozzle setting I can't >> remember the exact name of checked off, but it doesn't help. >> Meanwhile I watch my ink levels go down as cleaning is very >> frequent. Frustrating. >> >> Is the problem Epson LFP Remote Panel will not run on SL? >> >> >> > > Walker Blackwell > 802.821.4451 > www.walkerblackwell.com > aim: greendirtblues > wblackwell@googlewave.com > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish > to unsubscribe, please edit your Membership preferences by visiting > this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages > to keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group > Owner and Moderators. See Group Topic, Rules and Guidelines in the > Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE > LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE > PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE > DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; > OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO > GROUP. > Yahoo! Groups Links > > > > >
2009-11-18 by sagaface
Yep, I don't see the option you describe for your 11880 on my 7900, either. ? Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> > Please tell us where that menu is. My 9900 only shows off or on auto > nozzle check. > > Mark > http://www.stillrivereditions.com > > On Nov 17, 2009, at 11:11 PM, Walker Blackwell wrote: > > > Can't you just turn Auto Nozzle check/clean off on the printer? The > > 11880 lets you do this. You can also set the auto nozzle clean per/5/ > > print thing to 30 or whatever you need. This should do it. I don't see > > why you need to update firmware. > > > > Walker > > > > On Nov 16, 2009, at 8:52 PM, johnvphoto wrote: > > > >> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" > >> <sagaface@> wrote: > >>> > >>> I'm running the latest version of Snow Leopard....the Epson tech > >> told me I could not update firmware with SL until Spring, which is > >> supposedly going to make the cleaning cycles less aggressive. I have > >> both the Auto Nozzle Check and another nozzle setting I can't > >> remember the exact name of checked off, but it doesn't help. > >> Meanwhile I watch my ink levels go down as cleaning is very > >> frequent. Frustrating. > >> > >> Is the problem Epson LFP Remote Panel will not run on SL? > >> > >> > >> > > > > Walker Blackwell > > 802.821.4451 > > www.walkerblackwell.com > > aim: greendirtblues > > wblackwell@... > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Please visit the Group Homepage to check the Files, and other > > resources as they are often being updated. > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > If you wish to receive no emails or just a daily digest, or you wish > > to unsubscribe, please edit your Membership preferences by visiting > > this same page. > > > > Please follow these basic guidelines: > > - As threads develop, trim off excess portions of earlier messages > > to keep them short. > > - Good manners are required at all time. No personal attacks or > > flames. Hostile, aggressive or argumentative users may be removed > > from the membership without notice. > > - Keep your posts and threads related to the group topic of digital > > B&W printing. Users who persistently make off-topic posts may be > > removed from the membership. > > - By posting on this forum you agree to abide by the group rules and > > guidelines, and to abide by the actions and decisions of the group > > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the > > Files section: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE > > LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE > > PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE > > DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR > > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; > > OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO > > GROUP. > > Yahoo! Groups Links > > > > > > > > > > >
