Getting started : MIS inks
2009-12-12 by tati1806
I purged my epson 1270 with the mis cartridges...followed a procedure to
print a purge sheet...
then installed MIS ut fsn cartridge for the grays and MIS eboni
black...when I print the purge sheet again all I get is the black
cartridge printing...the other five bars which should be shades of gray
don't print...
any suggestions?
thanks in advance...
Re: Getting started : MIS inks
2009-12-13 by bmarsolais
> any suggestions?
More than once I forgot to take off the tape over the air vent.  That will prevent printing.  You might check to make sure you removed it.
When is the last time you printed a good nozzle check with it?
Bob
