MIS refillable cartridges with a front filter ?
2009-12-13 by hindibook
I recently bought a set of MIS refillable cartridges for my Epson 2200, these are the type that have a filter in the front section.  I asked MIS how many times these could be refilled but only got back a vague answer of a few times.  I know when refilling OEM carts foam can forum in the sponge and start causing problems after a while, don't know if these carts will do the same.
Anyone have experience with these? Is it better to keep them topped up, say refill when the are half empty or ??
Thanks for any advice
Tim
Re: [Digital BW] MIS refillable cartridges with a front filter ?
2009-12-13 by Leslie Otterbein
Hi Tim:
I have used the same cartridges multiple times (don't remember how
often I've refilled them) over a couple years or more. Whenever one
cartridge is near empty, I will fill any others that are less than
half full. This saves on cleaning cycles. One must remember to prime
the cartridge when installing new, and they work pretty well. Foam has
never been a problem. Sometimes I notice air around the bottom near
the outlet; you can shake the air up to the top when refilling (with
the stopper still in of course).
Leslie Otterbein
> Tim
Leslie Otterbein
photo-art-les.com
web.me.com/lotterbein
OK thanks Leslie the filter does not look like it's a sponge more like fiber and if you don't let them run dry I wouldn't think they would foam up. I tried a set of spongeless ones I got on ebay but 4 of them leaked out all the ink through print head (what a mess). The MIS carts are working great so far.
Tim
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Leslie Otterbein <lotterbein@...> wrote:
> Hi Tim:
> Leslie Otterbein
> > Tim
> Leslie Otterbein
> photo-art-les.com
