Cooled C6 on matte and warmed HP PK C6 on glossy (with DMax 2.86)
2010-02-05 by santonov2you
Hi all! Finally I fixed my old 2200 and put there mix of C6 diluted HP PK inks and couple carbon inks from MIS that are compatible with glossy paper. Idea was to warm up black tones a little bit, I think pure HP PK is too cold in black. Inks positions are: K - HP PK 100% LK - HP PK 33% C - MIS UT7 C M - HP PK 16% LC - MIS UT7 LC LM - HP PK 8% Y - MIS Glop On Kirkland paper this setup produced DMax 2.86, something I didn't expect at all. I spent some time figuring out QTR profile, because using K as gray curve produced very weak 100% spot, it had L 12 and 95% spot was 3.2. At the end I changed inks setup and used MIS inks as grays and HP inks as toners. You could see table with 21 patches ramp here <http://cid-b0975f9c313515c7.skydrive.live.com/self.aspx/.Public/Kirklan\ dGraph%5E_C6%5E_HPPK.gif#resId/B0975F9C313515C7%21164> , and curve with Lab b here <http://cid-b0975f9c313515c7.skydrive.live.com/self.aspx/.Public/Kirklan\ dGraph%5E_C6%5E_HPPK.gif#resId/B0975F9C313515C7%21163> , sorry I don't have usable Web page, and put these picture to SkyDrive. I will try to make profile more neutral. On my 2200 pure HP PK has heavy microbanding, much worse than on 1400, and not suitable for BO printing. Probable it was a reason why 100% black spot was so weak. Mix of warm carbon MIS inks and HP PK is very smooth. Glop doesn't help too much -- where paper has no inks, it still has visible gloss differential. So Paul's suggestion worked fine. I am really surprised by DMax, in the black spot my spectro measured L 1.26, and non-linearized profile reading was 1.13. I could expect that Silver Rag will be even darker. I also put matte compatible inkset into 1400. Here my goal was to cool down highlight and produce more neutral tones. I used 8% dilution of HP PK in Y position, replacing 2% dilution of Eboni, inks positions are K - 100% Eboni C - 33% Eboni M - 16% Eboni Y - 8% HP PK LC - 8% Eboni LM - 4% Eboni Y ink was used as toner, I moved toner curve to highlights a little bit. I prepared two profiles, one with diluted HP PK, other one just Eboni. With this setup the best DMax was on PremierArt Matte BW 200 -- I still have some leftovers. I got DMax 1.71 with C6 only and 1.7 with cooled inkset. Again, table with measurements is here <http://cid-b0975f9c313515c7.skydrive.live.com/self.aspx/.Public/Kirklan\ dGraph%5E_C6%5E_HPPK.gif#resId/B0975F9C313515C7%21165> , and Lab b graphs for cooled and non-cooled inkset are here <http://cid-b0975f9c313515c7.skydrive.live.com/self.aspx/.Public/Kirklan\ dGraph%5E_C6%5E_HPPK.gif#resId/B0975F9C313515C7%21166> . Cooled down inkset produces quite neutral prints, highlights are not warm at all. Visually tone of glossy inkset that I used for Kirkland paper is somewhere between cooled and non-cooled tones for matte paper. I profiled some other matte papers too, got about the same tones, but DMax was lower than on MatteBW. I am expecting delivery with HPR and PremierArt Smooth FA 200 (Alise Museum is backordered) and couple papers from Red River, after that I will profile these too. Cooled tone looks very nice on PA FineArt 205 (which is natural paper, but DMax is "only" 1.59). Looking at DMax, matte paper can't hold the candle to If anyone is interested in using these non-standard inksets, I could upload my profiles. I selected 2200 for glossy papers over 1400 because of extra slot for glop, but if you drop glop, same glossy setup could be used on any 6 inks printer. These setups are probably not compatible with Epson driver, but I don't use it at all. Thanks to Paul Roark for good ideas, Sergei [Non-text portions of this message have been removed]
