hello gino,
as dieter said, it's difficult to explain.
as soon as you dial in large amounts of feedback,
the smaller bbd's have advantages soundwise, because
their resonance sounds cleaner (less distortion).
on the other hand the bigger bbd's are more versatile
because of the longer delay times.
so there is no "best choice" without considering the
wanted application. if you want all effects, you will
have to buy more than one version (a small and a large one?).
the best allrounder is probably the 1024 stages version,
but i can only speak for myself here.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...>
wrote:
> Gino,
> it's hard to explain the differences - aside from those which are
obvious
> (longer delay times with longer BBDs). And this is why Ingo made
the sound
> examples and I really thank him for this as I would not have the
time.
> In general shorter BBDs are better if you prefer to emphasize the
higher
> frequencies of the effect signal (e.g. flanging effect with or
without
> feedback that affects mainly higher frequencies, or Karplus Strong
with
> higher notes). But it's not only the frequency or the delay time.
Even the
> resonance/feedback behaviour is different for different BBD
circuits. It's
> hard to explain. As the BBD circuits are not very expensive (except
the 4096
> type MN3005) you could order one module A-188-1 together with some
BBD
> circuits as spare parts and find out which BBD type you prefer. But
you
> should wait for the revised version of the module that allows to
use nearly
> all BBD circuits of the MN3xxx series (except those with another
basic BBD
> structure, like the MN3010, MN3011, MN3210 or MN3214).
> Best wishes
> Dieter Doepfer
> > -----Ursprüngliche Nachricht-----
> > Von: Doepfer_a100@yahoogroups.com
> > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Robair, Gino
> > Gesendet: Montag, 24. April 2006 23:35
> > An: Doepfer_a100@yahoogroups.com
> > Betreff: [Doepfer_a100] BBD question: which one?
> > Thanks for the examples, Ingo.
> > Here's a strange question for you (and Dieter, if has some
thoughts about
> > it): how does one determine which bbd (which number of stages) to
> > purchase,
> > without hearing and trying each one? Is it possible to describe
the sound
> > and behavior of each bbd succinctly? The two I tried at
Musikmesse clearly
> > sounded different from each other, though I can't remember which
they
> > were...
> > ginorobair
> > On 4/24/06 2:27 PM, "Doepfer_a100@yahoogroups.com"
> > <Doepfer_a100@yahoogroups.com>scribbled:
> > > From: "selfoscillate" <synaptic_music@...>
> > > Subject: bbd examples for 128 stages
> > > hello all,
> > > here are some more a188/1 bbd prototype examples,
> > > this time using an 128 stages ic (mn3006).
> > Yahoo! Groups Links
