Doepfer
Module Ideas: Universal "breakout box"
2006-05-09 by mrb
Hey everyone:
This may be a *bit* hard to explain, but it's been kicking around in
my head for ages, and I planned to manufacture and get rich off it
(snicker) but instead, i'll share it and see if anyone else thinks
it's viable!
The Universal Breakout Box module would be a control interface for a
"knob box" like the Doepfer Pocket controller, to solve the problem
many people like me have with the Doepfer: when it's VERY patchy, it's
hard to get in there and turn knobs on the fly.
The module part of the "system" would be a single wide (4 "channels")
or double wide (8 "channels") where each "channel" would consist of an
input jack, an attenuator knob, and an output jack.  Any signal path
you would like to attenuate manually could be "finely" attenuated with
the knob on the panel, and then "coarsely" attenuated with the knob on
the breakout box, which would connect to the panel by a cable (serial?).
This completely passive system (although gain stages, buffers, etc.
would be a cool addition) would allow you to have a tabletop box for
controlling any parameter of your synth in real time.  The knob of
each channel would be "between" the input and output, allowing you to
diversely control anything without having to reach in there, possibly
knock something out, etc.
This makin sense?
RE: [Doepfer_a100] Module Ideas: Universal "breakout box"
2006-05-09 by Zoran Bosnjak
OK, how about this sci-fi idea: you buy module, and patch it into the large
button-based matrix (like EMS AKS, but buttons instead of pins.) You label
rows and columns yourself. It is like large DIY matrix panel.
And style of the buttons? Well, if engaged, they should be lit, like those
old style elevator keys.
Regards, and don't take this too seriously,
Zoran
>From: "mrb" <boredom_cz@yahoo.com>
>Reply-To: Doepfer_a100@yahoogroups.com
>Subject: [Doepfer_a100] Module Ideas: Universal "breakout box"
>Date: Tue, 09 May 2006 20:48:06 -0000
>Hey everyone:
>it's viable!
>This makin sense?
Re: [Doepfer_a100] Module Ideas: Universal "breakout box"
2006-05-10 by Bakis Sirros
you mean to have a tabletop multiple cv source
connected via a cable to a multiple attenuation
module?
would this make any difference?
regards,
Bakis.
--- mrb <boredom_cz@yahoo.com> wrote:
> Hey everyone:
> kicking around in
> get rich off it
> anyone else thinks
> it's viable!
> interface for a
> solve the problem
> VERY patchy, it's
> wide (4 "channels")
> would consist of an
> Any signal path
> tabletop box for
> time.  The knob of
> in there, possibly
> This makin sense?
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
http://mail.yahoo.com
hello zoran,
that sounds very interesting too.
dieter?
regards,
Bakis.
> matrix panel.
> Zoran
> "breakout box"
> >Hey everyone:
> kicking around in
> get rich off it
> anyone else thinks
> >it's viable!
> solve the problem
> wide (4 "channels")
> would consist of an
>  Any signal path
> tabletop box for
> time.  The knob of
> in there, possibly
> >This makin sense?
Athens-Greece
Do You Yahoo!?
2006-05-10 by guido de zeeuw
This is handy, but a typical DIY project I think.
Make yourself a faderbox, or saw the faderpart of an obsolete mixer.
I would solder pieces of 1 meter wire direct to the faders and then a
plug
to the other end, that will save on plugs and connectors (on the
mixer), you never will unplug !
On May 9, 2006, at 22:48, mrb wrote:
>  Hey everyone:
>  it's viable!
> (serial?).
>  This makin sense?
> SPONSORED LINKS
> Electronic air filter
> A100
> Midi converter
> Modular system
> Module
> YAHOO! GROUPS LINKS
> 	▪ 	 Visit your group "Doepfer_a100" on the web.
> 	▪ 	 To unsubscribe from this group, send an email to:
>  Doepfer_a100-unsubscribe@yahoogroups.com
> 	▪ 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
