General suggestion for new modules
2006-05-16 by Florian Anwander
Hi The last days I worked a lot with the A100 and tried also to customize some modules. From this background and from the lot of new ideas of the discussions here in the last week, I'd like to suggest two technical things: 1.) If possible, please always provide two parallel sockets for each output. I never have enough multiples. And very often I only want to split a connection or simply have a measuring point for a voltmeter or oscilloscope. 2.) the connection traces for sockets on the pcb most times are routed that way, that any kind of additional normalling ist not possible (or at least requires breaking up the lines, and rewiring them). Until now most connections come from the electronics, go to the normalled switch contact of the socket and are wired through to the in/output contact of the socket. It would be much better for any customizing if the connection to the electronics are connected only to the in/output contact and the normalled swicth contact would be free for additions. thanks Florian
