Doepfer
RE: [Doepfer_a100] Re: ideas/opinions on quantizer and (VC) arpeggiator
2006-05-17 by David Salter
Good explanation Florian
Thanks
David Salter
Senior Project Manager
Reuters Ltd
Tel       +44 20 7542 2402
Mob     +44 7990562402
email    david.salter@reuters.com
RM       david.salter.reuters@reuters.net
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of Florian Anwander
Sent: 17 May 2006 12:20
Subject: Re: [Doepfer_a100] Re: ideas/opinions on quantizer and (VC)
arpeggiator
Hi Levka
> I do not yet understand completely what Florian means by this;
> Florian; Could you perhaps elaborate a little on this ?
Ok, but it will be a little bit longish...
Originally an arpeggiator as in Roland Jupiter Series, in SH101 or in
the Korg Monopoly/Polysix was a simply "misusage" of the keyboard
scanning electronics. The keyboard of these synths is like a matrix
scanner. The electronics send addresses (usally 6Bit) in a certain order
to this matrix, read the data (=pressed keys) from this matrix into a
buffer, and distribute these (key-)data from the buffer to the sound
generation.
Usually this reading from the buffer is very(!) fast (at some hundered
kHz rate). For arpeggiating the buffer is simply read slowly at the rate
of the (internal or external) clock of the arpeggio.
So at each trigger of the clocksignal provides the next key data to the
sound generation.
For up, down, up/down arpeggios you simply change the way the matrix of
the keyboard is addressed. whether the adresses are counted up or down
or....
This is the classic arppeggio function in basic.
Now you may imagine, that it would be great to have influence on the
address data of the keyboard scanner. Example: normally the order of the
notes are
  adresse 000 001 010 011 100 101 110 111  (order= a0 a1 a2)
  notes    c   c#  d   d#  e   f   f#  g
If I press a c-major the order of the notes in the buffer will be
"c e g". A c-sus9 will be "c d f g"
Now i simply invert adress a1:
  adresse 010 011 000 001 110 111 100 101
  notes    d   d#  c   c#  f#  g   e   f
Now the order of the notes in the buffer (and the order of an arpeggio)
will be "c g e". The c-sus9 is now "d c g f"
You see that a simple conversion of the address data does create
complete new arpeggio patterns. Imagine what is possible, if you do such
conversion depending on other sequencings, on states of some
controlvoltages or what ever...
I know, that a MIDI based arpeggiator system would have to simulate
this, but I think, it would be worth the effort :-)
Florian
YAHOO! GROUPS LINKS
*	 Visit your group "Doepfer_a100
<http://groups.yahoo.com/group/Doepfer_a100> " on the web.
*	 To unsubscribe from this group, send an email to:
	 Doepfer_a100-unsubscribe@yahoogroups.com
<mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
To find out more about Reuters visit www.about.reuters.com
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Ltd.
