RE: [Doepfer_a100] Re: ideas/opinions on quantizer and (VC) arpeggiator
2006-05-18 by David Salter
Where ever possible I would prefer to always have the option of CV/gate. I don't use midi much as I find the 128 step quantising very limited. Rgds David David Salter Senior Project Manager Reuters Ltd Tel +44 20 7542 2402 Mob +44 7990562402 email david.salter@reuters.com RM david.salter.reuters@reuters.net ________________________________
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Dieter Doepfer Sent: 18 May 2006 12:44 To: Doepfer_a100@yahoogroups.com Subject: AW: [Doepfer_a100] Re: ideas/opinions on quantizer and (VC) arpeggiator Sounds interesting for me too. How should the input of the notes be managed - if not via Midi (e.g. with several CV inputs)? Or is Midi the only option from your point of view ? Or a separate keyboard just for this function (e.g. with small buttons only, like the buttons used in the A-107 or A-113) ? Best wishes Dieter Doepfer > -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von levka0 > Gesendet: Mittwoch, 17. Mai 2006 20:39 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] Re: ideas/opinions on quantizer and (VC) > arpeggiator > > > Many thanks Florian ! > > This is a very clear explanation to me. > > So for a 6 bit buffer, 32 adresses would be scanned an their order > could be remapped according to a certain control voltage ? > Reminds me of a wavetable. > Instead of the usual up/down/up+down order, this would mean an almost > infinite number of patterns (that is, if all 32 adresses are filled) > Probably 4 bit (8 notes ?) should be enough and would keep this > feasible regarding the number of possible sequences. > > I think this could be a very interesting & exciting concept for a module. > > Best regards > Joost > > > > > --- In Doepfer_a100@yahoogroups.com, Florian Anwander > <Florian.Anwander@...> wrote: > > > > Hi Levka > > > > > I do not yet understand completely what Florian means by this; > > > Florian; Could you perhaps elaborate a little on this ? > > Ok, but it will be a little bit longish... > > > > Originally an arpeggiator as in Roland Jupiter Series, in SH101 or in > > the Korg Monopoly/Polysix was a simply "misusage" of the keyboard > > scanning electronics. The keyboard of these synths is like a matrix > > scanner. The electronics send addresses (usally 6Bit) in a certain > order > > to this matrix, read the data (=pressed keys) from this matrix into a > > buffer, and distribute these (key-)data from the buffer to the sound > > generation. > > > > Usually this reading from the buffer is very(!) fast (at some hundered > > kHz rate). For arpeggiating the buffer is simply read slowly at the > rate > > of the (internal or external) clock of the arpeggio. > > So at each trigger of the clocksignal provides the next key data to the > > sound generation. > > > > For up, down, up/down arpeggios you simply change the way the matrix of > > the keyboard is addressed. whether the adresses are counted up or down > > or.... > > > > This is the classic arppeggio function in basic. > > > > Now you may imagine, that it would be great to have influence on the > > address data of the keyboard scanner. Example: normally the order of > the > > notes are > > adresse 000 001 010 011 100 101 110 111 (order= a0 a1 a2) > > notes c c# d d# e f f# g > > If I press a c-major the order of the notes in the buffer will be > > "c e g". A c-sus9 will be "c d f g" > > > > Now i simply invert adress a1: > > adresse 010 011 000 001 110 111 100 101 > > notes d d# c c# f# g e f > > Now the order of the notes in the buffer (and the order of an arpeggio) > > will be "c g e". The c-sus9 is now "d c g f" > > > > You see that a simple conversion of the address data does create > > complete new arpeggio patterns. Imagine what is possible, if you do > such > > conversion depending on other sequencings, on states of some > > controlvoltages or what ever... > > > > > > > > I know, that a MIDI based arpeggiator system would have to simulate > > this, but I think, it would be worth the effort :-) > > > > > > > > Florian > > > > > > > > > > > > Yahoo! Groups Links > > > > > > SPONSORED LINKS Electronic air filter <http://groups.yahoo.com/gads?t=ms&k=Electronic+air+filter&w1=Electronic+air+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=4z4o_X8-pJMV_ZkWpcUzfQ> A100 <http://groups.yahoo.com/gads?t=ms&k=A100&w1=Electronic+air+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=vkZk9oMwSYA6JVt7jMKACg> Midi converter <http://groups.yahoo.com/gads?t=ms&k=Midi+converter&w1=Electronic+air+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=8wIjtHrgvO_CLHjOsXjwXA> Modular system <http://groups.yahoo.com/gads?t=ms&k=Modular+system&w1=Electronic+air+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=k_-XvCuWrHEHytqPA5h6eQ> Module <http://groups.yahoo.com/gads?t=ms&k=Module&w1=Electronic+air+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=wsqwVmN_jTYb6sPVmjGuHg> ________________________________ YAHOO! GROUPS LINKS * Visit your group "Doepfer_a100 <http://groups.yahoo.com/group/Doepfer_a100> " on the web. * To unsubscribe from this group, send an email to: Doepfer_a100-unsubscribe@yahoogroups.com <mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . ________________________________ To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Ltd. [Non-text portions of this message have been removed]
