Doepfer
RE: [Doepfer_a100] Problems with 4096 stages BBD modules
2006-05-19 by David Salter
Dieter,
Thank you for the clear and concise answer.
I think I'll buy a couple of modules just to be on the safe side :o)
Rgds
David
David Salter
Senior Project Manager
Reuters Ltd
Tel       +44 20 7542 2402
Mob     +44 7990562402
email    david.salter@reuters.com
RM       david.salter.reuters@reuters.net
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of Dieter Doepfer
Sent: 19 May 2006 09:55
Subject: AW: [Doepfer_a100] Problems with 4096 stages BBD modules
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von David Salter
> Gesendet: Freitag, 19. Mai 2006 10:29
> Betreff: RE: [Doepfer_a100] Problems with 4096 stages BBD modules
> Excuse my ignorance here as I'm sure it's been said before.
> When I purchase a BBD module will I be able to swap different BBD
> chips, i.e. are the chips pin compatible?
> Thanks
> David
David,
it depends .....
For the first two series of A-188-1 only these BBD circuits can be used:
MN3204 (512 stages)
MN3205 (4096 stages)
MN3206 (128 stages)
MN3207 (1024 stages)
MN3208 (2048 stages)
MN3209 (256 stages)
The other BBD circuits can be used only with some modifications (additional parts and wiring, interrupted pcb tracks). But we do not recommend this. We also manufactured a small quantity of adapter boards for the MN3005 (4096) so that this BBD can be used even in the first module series. We had many customers who wanted badly to have the module with 4096 stages and asked if there is a change without waiting for the revised module (~ June 2006).
From the third series of A-188-1 (available about end of June 2006) the revised version of the module is delivered. In this version additionally these BBD circuits can be used:
MN3004 (512 stages)
MN3005 (4096 stages)
MN3006 (128 stages)
MN3007 (1024 stages)
MN3008 (2048 stages)
MN3009 (256 stages)
The type of BBD module can be selected with several jumpers on the pc board of the revised version.
But in every case the module has to be re-adjusted because of the different clock range of the BBD circuits (see A-188-1 user's manual), the different resonance/feedback behaviour and two other required adjustments (balance/symmetrical clipping and clock feedthrough). Four trimming potentiometers have to be readjusted (clock offset, max. feedback, balance/clipping, clock feedthrough). An oscilloscope and frequency meter is recommended but one could try the adjustments even by trial and error. An appendix is planned for the A-188-1 manual that describes the adjustments and how to change a circuit (different cases and pin numbers).
Best wishes
Dieter Doepfer
------------------------ Yahoo! Groups Sponsor --------------------~--> Home is just a click away.  Make Yahoo! your home page now.
http://us.click.yahoo.com/DHchtC/3FxNAA/yQLSAA/QnLolB/TM
Yahoo! Groups Links
To find out more about Reuters visit www.about.reuters.com
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Ltd.
