Doepfer
Request for advice using Schaeffer Panel designer
2006-05-20 by stuadh
  has anyone used Schaffer Panel Designer?  I'v recently started using
it and I'd appreciate advice on how to generate graduated dials around
pots and if there is a way to print rather than engrave onto panels?
Yours Aye
Stuadh
Re: Request for advice using Schaeffer Panel designer
2006-05-21 by Tim Stinchcombe
Hi Stuadh,
using
around
It is very, very easy once you get it sussed. The key I think is to
read the 'How do I create a round scale?' FAQ on the 'Support' page:
http://www.schaeffer-ag.de/index.php?
option=com_content&task=view&id=82&Itemid=201&lang=en
I can't quite remember how to set the '(x,y)' or '(dx,dy)' coords about
which it rotates, but it is something like:
- right click, 'move/rotate'
- check 'apply action to copy'
- set the required angle
- hit 'OK'
- then right click, 'move/rotate', 'OK' as many times as required
And don't forget to carefully check the total rotation of the pots you
are using, or you might make an expensive mistake!
(As for the printing, my guess would be not.)
Tim
