Doepfer
[Doepfer_a100] Re: offset
2006-05-23 by Bryan E Cornell
Practice turning the knob very fast and you can be your own envelope generator!
Bryan
>>> techmeier@web.de 05/23/06 12:40 PM >>>
If nothing is connected to In 1 the pot will simply add V to the
output of the mixer. The V range goes from 0V (fully ccw) up to 5 V
(fully cw).
E.g. your CV for a VCA is an LFO since it's range goes from -2,5 to
+2,5 you will only hear the audio signal if the CV is above 0 V;
when it equals 0 V or goes below the VCA will be silent.
Same patch but the LFO goes into In 2 of an A138 before it feeds the
VCA. Now you can add some positive Vs with the pot In 1 which acts a
Voltage source (same as A176) if there's no connection to it's
corresponding jack. This allows you to off set the negative V of the
LFO for a varying audio output so that the VCA never mutes the
signal but varies it's amplitude.
Regards, Ingo
--- In Doepfer_a100@yahoogroups.com, "Richard" <richardscott@...>
wrote:
> thanks guys
> I don't quite get what a138 does. If I don't plug anything into
the first input does that mean I can effectively control the output
so it can't go over 5v or under 0v?? somehow my brain and the
description in the pdf are not connecting.
> Richard
>   ----- Original Message -----
>   From: selfoscillate
>   To: Doepfer_a100@yahoogroups.com
>   Sent: Tuesday, May 23, 2006 7:56 AM
>   Subject: [Doepfer_a100] Re: offset
>   hello richard,
>   you can do this with the a138 mixer modules,
>   which were manufactured after april 2004.
>   or you can use an a129/3.
>   best wishes
>   ingo
>   --- In Doepfer_a100@yahoogroups.com, "Richard" <richardscott@>
wrote:
>   > Hi
>   > I want to attentuate and offset an LFO output so I can send it
to a
>   +5v destinarion (alesis andremeda pedal input) is there a
doepfer
>   module which can do this elegantly/cheaply?
>   > Richard
>   > [Non-text portions of this message have been removed]
>   SPONSORED LINKS Electronic air filter  A100  Midi converter
>         Modular system  Module
>   YAHOO! GROUPS LINKS
>     a..  Visit your group "Doepfer_a100" on the web.
>     b..  To unsubscribe from this group, send an email to:
>      Doepfer_a100-unsubscribe@yahoogroups.com
>     c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
SPONSORED LINKS
Electronic air filter A100 Midi converter Modular system Module
YAHOO! GROUPS LINKS
