Schematic of wasp filter.
http://www.oldcrows.net/~jhaible/tonline_stuff/hj_wasp.jpg
Hello,
How about changing the clipping diodes in the resonance path.
If you change one to a led or silicium you should get asymetric clipping.
Has anyone tried that?
Best Dirk.
Hi Dirk
As far as I know the schmatics of Juergen Haibles wasp filter differs
from the one Doepfer is using.
Florian
> Best Dirk.
We did a similar trick in the A-106-1 and replaced each clipping diode by a
potentiomer + diode (connected in series). This allows to adjust both the
positive and negative clipping level (CL+ and CL- controls of the A-106-1).
By using the universal vactrol module A-101-9 both parameters can be voltage
controlled (potentiometer + vactrol output connected in parallel).
The corresponding diodes are labelled D3/D4 in the original Wasp schematics
of Electronic Dream Plant (EDP) and D1/D2 in the A-124.
Best wishes
Dieter Doepfer
b.t.w. We added a mod to the A-100 DIY page that allows self-oscillation for
the A-124.
> Hi Dirk
> Florian
Right. The A-124 is based on the original Wasp circuit/schematics of
Electronic Dream Plant/EDP (2xCA3080+CD4069). But we used another type of
logarithmic current source for the CA3080 control current and replaced the
separate HL and LP outputs by a single mix output with an additional mix
control (HP/LP share) to obtain a notch filter in its center position.
I'm not sure if it is idential to Juergen Haible's circuit but I don't think
so.
Best wishes
Dieter Doepfer
