Doepfer
Ways to limit the LFO range...
2006-06-26 by danfarmer19732003
Hi guys... I'm looking for what I might call a range limiter for my
LFOs.
What I want to do is limit the range of the LFO. For example, if I'm
controlling the cutoff filter with the LFO I do not want the filter to
close the filter 100%, I just still want some sound(s) to come through.
I'm finding that as it is right now, there is no EFFECT AMOUNT control
on the LFO's it just does a straight 0-100% range.
The opposite is true as well, in some case where I do not want 100% of
the sounds to come through either. Meaning that I do not want the LFO
opening up the cutoff filter 100%.... again some king of EFFECT AMOUNT
control would be useful to me.
Can the Deopfer A-136 do this? If not what other module can? I was
thinking if I routed the LFO through a filter and if that filter had
bandpass, that that might do what I want.
Re: Ways to limit the LFO range...
2006-06-26 by untiedstates
A-138c polarizing mixer - or the polarizing module (not sure the #).
--- In Doepfer_a100@yahoogroups.com, "danfarmer19732003"
> LFOs.
2006-06-26 by selfoscillate
hello dan,
you can simply attenuate the lfo output,
that would be the simplest solution.
the more elaborated solution would be the use of
one or two a172 max/min modules together with an
a176 voltage source, thats what i'm doing quite often.
best wishes
ingo
> LFOs.
I'm
to
through.
control
of
LFO
AMOUNT
had
Hi Ingo... when you say...
"you can simply attenuate the lfo output, that would be the simplest
solution."
What exactly do you mean? All I see on my LFO's is a rate knob that
controls the rate of the LFO. Can you give me an example of how to
attenuate the output?
> hello dan,
> best wishes
> ingo
my
> > LFOs.
> I'm
filter
> to
> through.
> control
100%
> of
> LFO
> AMOUNT
was
> had
2006-06-26 by ilanode
Hello Dan, Doepfer LFO-modules have no level controll for the output
but most (if not each) have at least one input with a level control
(attentuator). The VCFs have usually one input without attentuator
(e.g. A122: CV1 for an 1/V response) and another one with
attentuator (e.g. CV2 for those CVs which does not need to comply
with the 1/V standard). Regards, Ingo (not selfoscilating)
simplest
> solution."
that
> > hello dan,
> > best wishes
> > ingo
for
> my
> > > LFOs.
if
> > I'm
> filter
> > to
> > through.
> > control
> 100%
> > of
> > LFO
EFFECT
> > AMOUNT
> was
filter
> > had
Sorry, for posting this twice. just have realized I missed a word
which is now added:
but most (if not each) *module* have at least one input with a level
control (attentuator). The VCFs have usually one input without
attentuator (e.g. A122: CV1 for an 1/V response) and another one with
output
control
> simplest
> > solution."
> that
to
> > > hello dan,
> > > best wishes
> > > ingo
> for
> > my
> > > > LFOs.
example,
> if
> > > I'm
> > filter
> > > to
come
> > > through.
AMOUNT
> > > control
want
> > 100%
> > > of
want
> the
> > > LFO
> EFFECT
> > > AMOUNT
I
> > was
> filter
> > > had
Hi again, thanks for your assistance but I'm afraid that I'm still
not following.
I have the following module and see no input to control the
attenuation...
http://www.analoguehaven.com/doepfer/a145/
> which is now added:
level
with
> output
> control
attentuator
> > simplest
> > > solution."
> > that
> to
> > > > hello dan,
> > > > best wishes
> > > > ingo
limiter
> > for
> > > my
> > > > > LFOs.
> example,
> > if
> > > > I'm
> > > filter
> > > > to
> come
> > > > through.
> AMOUNT
> > > > control
> want
> > > 100%
> > > > of
> want
> > the
> > > > LFO
> > EFFECT
> > > > AMOUNT
can?
> I
> > > was
> > filter
> > > > had
Sorry, for the insufficient explanation. I'll try again. You go from
the LFO's sine out into a VCF. Let's assume you take CV1 of the
A120. This input is calibrated to comply with the 1/V standard. The
sine output goes (just a guess) from -2,5 to +2,5 thus will swing
the freq. as if you would manually turn the freq pot over a wide
range. This is the current annoying situation. However, if you use
the CV2 or CV3 input you can attentuate the incoming sine wave with
it's corresponding CV-pot to any range inbtn. 0V and -/2,5V. The 2
attuators (CV2 and CV3) make of the missing output level control on
the LFO. Hope that helps, Ingo
> not following.
> attenuation...
word
> > which is now added:
output
> level
> with
> > output
> > control
> attentuator
comply
> > > simplest
> > > > solution."
knob
> > > that
how
> > to
> > > > > hello dan,
> > > > > best wishes
> > > > > ingo
> limiter
> > > for
> > > > my
> > > > > > LFOs.
> > example,
> > > if
> > > > > I'm
> the
> > > > filter
> > > > > to
to
> > come
> > > > > through.
> > AMOUNT
> > > > > control
not
> > want
> > > > 100%
> > > > > of
> > want
> > > the
> > > > > LFO
> > > EFFECT
> > > > > AMOUNT
> can?
> > I
> > > > was
that
> > > filter
> > > > > had
RE: [Doepfer_a100] Ways to limit the LFO range...
2006-06-26 by unknown freak
You should be using the CV input attenuator on the filter for that.  You're
simply looking in the wrong place.
--Chuck
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of danfarmer19732003
Sent: Monday, June 26, 2006 11:01 AM
Subject: [Doepfer_a100] Ways to limit the LFO range...
LFOs.
Re: [Doepfer_a100] Re: Ways to limit the LFO range...
2006-06-26 by christopher scapelliti
What module are you connecting it to? That¹s the module that should have the
attenuator, not the LFO.
F
Reply-To: <Doepfer_a100@yahoogroups.com>
Date: Mon, 26 Jun 2006 16:50:14 +0000
Subject: [Doepfer_a100] Re: Ways to limit the LFO range...
not following.
attenuation...
--- In Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> which is now added:
level
with
> --- In Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> ,
> output
> control
attentuator
> > simplest
> > > solution."
> > that
> to
> > > > hello dan,
> > > > best wishes
> > > > ingo
<mailto:Doepfer_a100%40yahoogroups.com> , "danfarmer19732003"
limiter
> > for
> > > my
> > > > > LFOs.
> example,
> > if
> > > > I'm
> > > filter
> > > > to
> come
> > > > through.
> AMOUNT
> > > > control
> want
> > > 100%
> > > > of
> want
> > the
> > > > LFO
> > EFFECT
> > > > AMOUNT
can?
> I
> > > was
> > filter
> > > > had
RE: [Doepfer_a100] Re: Ways to limit the LFO range...
This is what we're endeavoring to familiarize you with.  The attenuator is
on the CV2 input of the filter.
--Chuck
Sent: Monday, June 26, 2006 12:50 PM
not following.
attenuation...
AW: [Doepfer_a100] Re: Ways to limit the LFO range...
2006-06-27 by Dieter Doepfer
In the A-100 system the attenuators are located at the inputs of the modules
but not at the outputs as this principle is much easier from our point of
view than having the attenuators at the outputs. Most modules have this
input structure for control voltages:
one manual control or offset (e.g. manual filter frequency control)
at least one CV input with attenuator
With the manual control you adjust the offset of the parameter in question
(e.g. VCF filter frequency, VCA loudness, VCO pitch), with the CV attenuator
you adjust the amount of the effect of the external CV, e.g. how much a
triangle output of an LFO modulates the filter frequency.
I hope everything is a bit more clear now.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von danfarmer19732003
> Gesendet: Montag, 26. Juni 2006 18:50
> Betreff: [Doepfer_a100] Re: Ways to limit the LFO range...
> not following.
> attenuation...
> > which is now added:
> level
> with
> > output
> > control
> attentuator
> > > simplest
> > > > solution."
> > > that
> > to
> > > > > hello dan,
> > > > > best wishes
> > > > > ingo
> limiter
> > > for
> > > > my
> > > > > > LFOs.
> > example,
> > > if
> > > > > I'm
> the
> > > > filter
> > > > > to
> > come
> > > > > through.
> > AMOUNT
> > > > > control
> > want
> > > > 100%
> > > > > of
> > want
> > > the
> > > > > LFO
> > > EFFECT
> > > > > AMOUNT
> can?
> > I
> > > > was
> > > filter
> > > > > had
Re: [Doepfer_a100] Ways to limit the LFO range...
2006-06-27 by Florian Anwander
Hi Dan,
I think you missed until now completely the principles of mixing and
attenuating control voltages. Everything you want, can be done by the
cutoff frequency pot and the modulation amount (CV2 amount) at each the
filter module.
I recommend to read a good book on this.
Florian
> LFOs.
Florian Anwander                  |ConSol
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
