Doepfer
building a cabinet
building a cabinet
2006-06-28 by dennis henderson
is there any chance someone could send me detailed
pictures or a diagram of a DIY a100 cabinet. im still
getting ideas for wiring etc...also can someone
recommend third party powersupply. thanks.
~dennis
Do You Yahoo!?
http://mail.yahoo.com
Re: [Doepfer_a100] building a cabinet
2006-06-28 by Julian
My own old case -
http://www.port23.co.uk/synthdiy/a100/
That one was designed for battery use, but the same subracks are now mounted
in non-portable cases, and powered off this -
http://www.port23.co.uk/doepfer1.jpg
which contains a powerone hbb 1.5 a (its bolted tightly to the lid to help
with the thermal dissipation)
Julian
AW: [Doepfer_a100] building a cabinet
2006-06-28 by Dieter Doepfer
At the end of the A-100 DIY page the construction of an A-100 frame is
described in principle. I'd recommend to use in any case the front rails
with threaded inserts (for module mounting). The side plates, the rear side
and the bottom/top cover can be made with any material you like (even wood).
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von dennis henderson
> Gesendet: Mittwoch, 28. Juni 2006 03:38
> An: doepfer a100 yahoogroup
> Betreff: [Doepfer_a100] building a cabinet
> ~dennis
> Do You Yahoo!?
