Doepfer
new module suggestion.
2006-07-12 by James Husted
A newer "Multiples" module:
After seeing the poll for the new Buss Access module I thought it
would be nice to have a A-183 Multiples 3 module that would be a Dual
or Single active one-in-4-out multiple that would be good to fan out
to voltage sensitive modules (CV in on VCOs of course).
A "Rhythm Sequencer"
It would be 16 ON-OFF-ON toggle switches with leds. It would have a
CLOCK IN (rising edge). A RESET input jack tied to the 3rd position
of the toggle switches. A "AND" input jack that would be normallized
to the CLOCK IN and would have a "Logic AND" function applied to it
and the 1st position of the toggle switch row. The results show up on
two outputs, a GATE and TRIGGER out. So you put a clock in and when
you want a beat you flip the toggle to the 1st position, To have a
rest or no beat put the toggle to the middle position. To make less
then 16 steps flip the step one number higher to the 3rd position -
great for live jumping between sequence lengths. This row could also
have a have GATE and TRIGGER outs allowing two different GATE/TRIGGER
sequence outs (that never share a beat).
James Husted
The ErsatZ Planet Graphics and Sound
http://homepage.mac.com/ersatzplanet/
james.husted@mac.com
"Welcome to the first day of the rest of your money..."
Re: [Doepfer_a100] new module suggestion.
2006-07-12 by Florian Anwander
Hi
Yes Yes Yes Yes!!!!
But see my suggestions for a modular sequencing system ("ceterum
censeo..."):
This should not be a trigger sequencer, but a switch sequencer (with
DG409).
This means for the switch sequencer:
Module one:
16 three position switches.
Center position is off (pulldown resistor to ground).
Upper position is fed by bus, which is fed to a socket, which is
normalized to the trigger.
Upper position is connected for each switch to a socket. This row of
sockets is normalized to a bus, which is fed by socket. This socket
again is normalized to a trigger with adjustable gate length.
By the usage of normalize sockets you also could switch in sequence
between different audio- or CV-signals (not only triggers).
Module two:
Either A154
Or a simplified version of A-154 with
- clockgenerator, Tempo
- ext. clock in
- clock out
- clock out Gate length
- reset (four switches or one HEX encoder switch)
- ext. reset in
Module three:
similar like module one, but instead of the switches there should be
pots, which are connected to the sockets.
This system could be a followup to the A-155 (module numbers A-155-1/2/3?)
Florian
2006-07-12 by Bakis Sirros
hello james, florian,
ok, looks like new polls are on the way...
best regards,
Bakis.
--- Florian Anwander <Florian.Anwander@consol.de>
wrote:
> Hi
> Yes Yes Yes Yes!!!!
> system ("ceterum
> censeo..."):
> sequencer (with
> DG409).
> Module one:
> ground).
> socket, which is
> socket. This row of
> socket. This socket
> gate length.
> switch in sequence
> triggers).
> Module two:
> Either A154
> - ext. clock in
> - clock out
> - ext. reset in
> Module three:
> there should be
> Florian
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
http://mail.yahoo.com
2006-07-17 by Bakis Sirros
hello florian, dieter,
what about this suggestion?
should i create a poll about a 16 step sequencer in
two parts(one part for the trigger rows[the three
position 16 trigger switches] and the second part for
the cv rows?)
please, tell me the form that the poll should have,
and if its needed.
best regards,
Bakis.
wrote:
> Hi
> Yes Yes Yes Yes!!!!
> system ("ceterum
> censeo..."):
> sequencer (with
> DG409).
> Module one:
> ground).
> socket, which is
> socket. This row of
> socket. This socket
> gate length.
> switch in sequence
> triggers).
> Module two:
> Either A154
> - ext. clock in
> - clock out
> - ext. reset in
> Module three:
> there should be
> Florian
Athens-Greece
Do You Yahoo!?
AW: [Doepfer_a100] new module suggestion.
2006-07-17 by hardware@doepfer.de
In principle a modular sequencer with separate units for gate/trigger rows
and CV outputs is not a real challenge for us as it's very similar to the
A-155. But I think it is necessary also to discuss the mechanical solution
for such a sub-system as this the critical part from my point of view. So
far the mechanical construction of the A-100 is based on the 3U height and
all modules are 3U. For separate gate/trigger and CV units we'll need very
long horizontal devices (16 switches, sockets or controls in one row) that
do not fit so far to the mechanical concept of the A-100.
And I hope that nobody expects that each poll with good positive results
will be realized. The number of polls with positive results exceeds our
possibilities by far.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Bakis Sirros
> Gesendet: Montag, 17. Juli 2006 15:03
> Betreff: Re: [Doepfer_a100] new module suggestion.
> the cv rows?)
> and if its needed.
> best regards,
> Bakis.
> wrote:
> > Hi
> > Yes Yes Yes Yes!!!!
> > system ("ceterum
> > censeo..."):
> > sequencer (with
> > DG409).
> > Module one:
> > ground).
> > socket, which is
> > socket. This row of
> > socket. This socket
> > gate length.
> > switch in sequence
> > triggers).
> > Module two:
> > Either A154
> > - ext. clock in
> > - clock out
> > - ext. reset in
> > Module three:
> > there should be
> > Florian
> Athens-Greece
> Do You Yahoo!?
Re: AW: [Doepfer_a100] new module suggestion.
2006-07-18 by Florian Anwander
Hi Dieter
Though long horizontal modules would be an optimum, also the solution of
the A155 (two rows of eight switches) is possible; and also something
like two vertical rows of eight switches could be a possible solution.
My suggestion also is not written in stone. I could imagine 8-step
modules too, which can be cascaded.
Florian
