Controlling Doepfer with Roland SH-101
2006-07-17 by beatboxgestapo
Hello, I have a Roland SH-101 that I use to control my Doepfer modular system via CV & Gate (not midi). I haven't used it for a while, and I have noticed a problem when I tried to record with it yesterday. There is always a constant tone coming out of the Doepfer even when I am not pressing a key on the Roland SH-101. I have the CV and gate going out of the SH-101 into the VCO and the gate of the ADSR of the Doepfer respectively. It does play and change notes when I push the keys down on the SH- 101; it's just that there is always a tone coming out of it when there are no keys being pressed. I have played the Roland SH-101 by itself, and everything seems to work. There is no sound coming out of it when there are no keys being pressed. (It is quiet when I am not pressing any keys.) Another issue I have discovered separately from using it with the Doepfer is that when I hook my Roland TR-606 to the SH-101 I am unable to control the sequencer with the TR-606. (The sequencer in the SH-101 seems to work fine when used by itself when not connected to the TR-606) I have also tried another Roland drum machine (Boss DR- 110) to control the sequencer in the SH-101, but the same thing happens. So I feel it isn't the drum machine. I figure the problem may be with my Roland SH-101 and not the Doepfer or TR-606 since the 101 is always at the root of each hook-up. Does anyone here have any ideas what it might be? Or if it is something other than the SH-101? Or do I just have the Doepfer hooked up wrong? Any help is much appreciated. Thank you, The Beatbox Gestapo
