Doepfer
Help with A-156 Quantizer
2006-08-01 by Dan Levey
I just picked up the above module and am getting crummy results with
sequenced notes.  The output CV is extremely slewed on each note.
Reminds me of extreme Auto-Tuning on Vocals where each note is quickly
bent to the correct one.  Here it sounds dirty and messy, not what I
expected.  Is this the best this can do or is there a method to using
this module?
thanks, Dan Levey
http://www.REwireMusic.com
Re: Help with A-156 Quantizer -SOLVED
I solved this myself.  Needed a gate to the trigger input to go with
each note. That made it nice and smooth!
quickly
> this module?
> thanks, Dan Levey
AW: [Doepfer_a100] Help with A-156 Quantizer
2006-08-01 by hardware@doepfer.de
There should be no slew at the A-156 outputs but fast steps to the next
voltage that fits to the current settings (scale/chord/major/minor....). You
have to connect the CV out of the A-156 directly to the CV input of the VCO.
In this case  no slew should occur.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Dan Levey
> Gesendet: Dienstag, 1. August 2006 06:16
> Betreff: [Doepfer_a100] Help with A-156 Quantizer
> this module?
> thanks, Dan Levey
