hello thomas,
i had a problem with one of my 143-2's that was sold
very easily.
just check this:
unmount the module from the rack and insert a minijack
cable into one of the adsr outputs. then obnserve the
module from behind the face plate. maybe the tip of
the patchcord's minijack is touching the led's pins
that are running very closely behind the minijack
socket?
regards,
Bakis.
--- thomasborax <thomasborax@yahoo.com> wrote:
> hello again-
> i looked at the module and noticed the jumpers you
> indicated. the
> jumpers appear to me to be completely intact,
> connecting the circuit
> boards exactly as you indicate. the solder points
> on the board look
> solid.
> any other possbilities? as i said, each envelope
> works perfectly
> individually.
> ----tom
> --- In Doepfer_a100@yahoogroups.com, <hardware@...>
> wrote:
> > Tom,
> > maybe the normalling wire has been interrupted
> when you replaced the
> LEDs.
> > It's a blank wire going from the main contact of
> the first gate
> socket to
> > the switching contacts of the three remaining gate
> sockets (it leads
> from
> > JP2 of the first board to JP2 of the other three
> boards but
> crosswise: for
> > the upper board the solder point close to the
> printing "JP2" is
> used, for
> > the boards 2, 3 and 4 the solder points close to
> the front panel are
> used).
> > btw. you cannot measure the gate signal at the
> gate sockets 2, 3 and
> 4 as
> > the normalling from gate #1 is interrupted as soon
> as a plug is inserted
> > into the corresponding gate socket 2,3 or 4!
> > If a submodule is working as an LFO depends upon
> the settings of the
> > controls ! Not for all settings and patches an LFO
> is obtained. As an
> > example this patch/setting has to work as an LFO:
> EOD -> GATE IN,
> Attack =
> > 5, Decay = 5, Sustain = 0, Release = 5. Changing
> the time parameters
> (A/D/R)
> > will change the rise and fall time of the LFO.
> > Best wishes
> > Dieter Doepfer
> > > -----Ursprüngliche Nachricht-----
> > > Von: Doepfer_a100@yahoogroups.com
> > > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag
> von thomasborax
> > > Gesendet: Donnerstag, 31. August 2006 18:28
> > > An: Doepfer_a100@yahoogroups.com
> > > Betreff: [Doepfer_a100] a143-2 issue
> > > hi lads/lasses-
> > > i've been loving my a143-2 for quite some time.
> i have encountered
> > > a bug in the normalization, and i wondered if
> anyone else had the
> > > issue, or had a fix. i am happy to go into the
> ciruit itself and do
> > > a fix, if need be.
> > > here's the issue- the gate of env 1 is no
> longer triggering the
> > > other 3 envs (there are no gate/trigger signals
> present at the g
> > > jacksof 2,3, and 4).
> > > this is a wonderful feature of this module. i'd
> like to get her
> > > back to this. incidentally, the gate jacks work
> on all the envs,
> > > just not the normalized gate input 1 controlling
> all others. all
> > > the digital outs work etc. everything works
> fine.
> > > actually, now that i think about it. the module
> has been slightly
> > > buggy from the start. occasionally in "lfo
> mode", with patch cables
> > > routing the digtal outs into the gate jack,
> nothing happens.
> > > usually it starts blinking away like an lfo, but
> occasionally
> > > nothing.
> > > also, a few months ago, i noticed env 4 just up
> and stopped running
> > > in tandem with the others, but worked
> individually. then it jumped
> > > back up with the others.
> > > very odd. the only mod i've done to this module
> is i soldered in
> > > different colored LEDs, just to make my system
> look more like a
> > > carnival ride. i can't imagine how doing this
> could effect the
> > > operation, but i may be missing the picture.
> > > anybody?
> > > --------tom
> > > Yahoo! Groups Links
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
