Doepfer A-112 Module (Wave Module) - Questions
2006-09-05 by William
All, I've been working with the A-112 module...and not getting the results I want. I've used the Doepfer Wave dump utility to load the 'Wiard wave' File. ..That part went fine. Here is my question... If anyone has used this module...and felt satisfaction...then how did you configure it for playback as well as how did you cable it up? How did I cable up my module? I used an analog keyboard (Synthesizers.com) and ran the CV out/Gate out to the CV IN/Gate in on the A-112 Module. Now...what should I use as a control voltage so as to step thru the waves on the wave table? On playback I had the S1 switch set to 'Play' and the S2 Switch to 'Norm', and the S3 Switch to 'Frz'.... Any suggestions here? Yes, I did read thru the PDF on the A-112 as well. :-) Mahalo from Hawaii!!
