Poll results for Doepfer_a100
2006-09-06 by Doepfer_a100@yahoogroups.com
The following Doepfer_a100 poll is now closed. Here are the final results: POLL QUESTION: Would you like Doepfer to release a VC Arpeggiator module? [This module produces a CV-sequence on its output which is derived from a chord information at its input. Corresponding Gate-Outs are produced too. The CV-Sequence is derived from a selectable pattern (pattern not in the meaning of a sequencer, but the real theoretical meaning). Details on functions: Chord information may be provided by midi in, or built-in mini-keyboard, or both. The pattern is stored in a memory (EEPROM). The selection of the pattern could be done by MIDI PrgChange, by CV, and/or on a quasi digital level (switches or voltage ins (example from a A-160/161) which are read digitally). I suggest not to provide more than 32 patterns. It might be possible to transfer pattern data via MIDI and edit them in an external program. A pattern contains at least the order by which the notes of the chord should be played, the ryhtm and note length would depend on th eprovided clock (classic arpeggiator). Additionally a pattern might contain the rhythm in which the notes are played and the lenght of the played notes (extended arpeggiator as it can be found e.g. the Access Virus). Alternatively it might be possible to separate note order patterns and rhythmic patterns. The range of the arpeggio should be also controllable either by CV or (easier) on quasi digital level (switches, digital voltage ins). Possible Connections and Controls: MIDI in CV-In for transpose Clock-In CV-Out Gate-Out CV-in for Pattern select Manual knob for pattern select (provides internal a CV) Switches for pattern select sockets for digital adressing of the pattern by CVs CV-in for Range select switch(es) for range select sockets for digital adressing of the range by CVs] CHOICES AND RESULTS - Yes!, 14 votes, 60.87% - maybe..., 7 votes, 30.43% - no., 2 votes, 8.70% For more information about this group, please visit http://groups.yahoo.com/group/Doepfer_a100 For help with Yahoo! Groups, please visit http://help.yahoo.com/help/us/groups/
