Doepfer
g6 fuse problems
g6 fuse problems
2006-09-06 by michaeltritter
Wondering if Dieter or anyone can help with this one:
I've had 3 G6 racks for a couple of months. None of them have been problematic until
yesterday, when one of them blew a fuse. I replaced the fuse, and everything worked
again, until today, when the fuse blew again. I removed most of the modules, and the fuse
blew. I removed all of the modules, and a fuse blew. I then tested one of the other cases
by turning it on a few times, and eventually one of those blew too. I have tried different
surge protectors, different cables, different electrical circuits in my apartment -- same
thing.
It would seem that this would indicate either 1) some major problem with my building's
electricity (possibly but unlikely), or 2) two G6 power supplies that went defective at
exactly the same time (possibly but unlikely).
Any thoughts? If it is some crazy problem with New York city's electrical grid, I would
imagine the Doepfer racks wouldn't be the only things susceptible. But the fact that two
different boxes, tested with all different numbers of modules (none, a few, a bunch, and a
lot) kept blowing seems downright weird.
I am using 1/2 amp slow-blow fuses, and tested the outlets in the apartment, which are
all running pretty close to 115v (~117, ~120, etc.).
Is there something completely stupid and obvious that I'm missing?
Thanks anyone for any help.
Michael Tritter
New York City
AW: [Doepfer_a100] g6 fuse problems
2006-09-06 by hardware@doepfer.de
Michael,
really strange that the problems occur after a couple of months and with
several systems at the same time. Here is my suggestion (I assume that your
A-100 frames include PSU2 with the toroid transformer):
The 500 mA value is based on the recommendation by the the manufacturer of
the transformer. Though it never happened in our company we've been told
that the 500 mA fuses blow now and then during power on because of the
transient current (never while the unit is on for a while). That's why we
increased the recommended fuse value to 630 mA in the meantime (315 mA for
230V systems). I'd recommend to replace the fuse by 630 mA or the next value
you can get (even 750 mA would be OK). The value is not that critical as in
case of a short circuit even a fuse with a slightly higher value will blow.
And it's essential that a slow blow/time lag fuse is used. Fast or medium
fuses will blow during power on because of the transient current.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von michaeltritter
> Gesendet: Mittwoch, 6. September 2006 06:03
> Betreff: [Doepfer_a100] g6 fuse problems
> everything worked
> thing.
> Michael Tritter
> New York City
Re: g6 fuse problems
2006-09-06 by Tommy DOG
fuse
Hi Michael,
I had a problem with a G6 that turned out to be only visable after I removed all the
modules and looked closely at the power supply.
My unit had the old power supply and a part had melted. I was blowing fuses non stop and
couldn't figure out why. If you want to know which part the archives might mention it.
-could have been the transformer. Once I installed the PS2 or whatever the bigger/later
version everything was fine.
TD, NYC as well!
2006-09-07 by michaeltritter
Dieter & Tommy...
Thanks for the advice. There is definitely something weird going on as the different boxes
are both blowing fuses and they both have the newer power supply. I've plugged and
unplugged just about every combination of modules to no avail.
I am getting ahold of .75 amp fuses to see if that fixes the problem. If not, perhaps some
sort of ritual to remove evil spirits. This is weird.
Michael
> fuse
> Hi Michael,
and
> TD, NYC as well!
2007-01-18 by stimbox
Hello,
I have a G6 case with an older PS and think I blew a fuse.
Where is the fuse located?  I can't seem to find it.
Tim
AW: [Doepfer_a100] Re: g6 fuse problems
2007-01-19 by hardware@doepfer.de
> Hello,
> Thanks,
> Tim
www.doepfer.com > FAQ > A-100 > Which fuse is used in the A-100 frame (rear
panel):
The fuse is located at the mains inlet on the rear panel of the A-100 frame
(exception: suitcase version with mains inlet at the front). One has to
disconnect the mains cable and remove the fuse holder (e.g. with the aid of
a screw driver). The fuse holder is a small black plastic part that is
inserted into the mains inlet.
Best wishes
Dieter Doepfer
2007-01-20 by stimbox
Dieter,
Many thanks!
Problem solved.
Found the fuse and changed it.
All the best,
Tim
> Best wishes
> Dieter Doepfer
2007-01-22 by jalmari3
Would it be safe to try 250V/400mA slow fuse for 6U basic frame with
PSU2 in 230V/50Hz enviroment?
2007-01-23 by hardware@doepfer.de
The spec says 315 mA. But I think 400mA are temporarily tolerable.
Best wishes
Dieter Doepfer
