Doepfer
BBD HSVCO at low clock frequency question.
2006-09-13 by vliesgaard
At low clock frequency's you start to hear the HSVCO.
To remove this it is suggested that you filter the output.
But (I think, not yet received my A-188-1) you can also subtract the
clock from the output with e.g. an A-138c.
Are there any advantages/disadvantages between the 2 methods?
AW: [Doepfer_a100] BBD HSVCO at low clock frequency question.
2006-09-13 by hardware@doepfer.de
This will not work as the clock pulses appear with different levels at the
BBD output (= the audio input signal sampled at each clock pulse). But the
BBD clock signal has a constant level.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von vliesgaard
> Gesendet: Mittwoch, 13. September 2006 08:41
> Betreff: [Doepfer_a100] BBD HSVCO at low clock frequency question.
Re: BBD HSVCO at low clock frequency question.
2006-09-13 by selfoscillate
--- In Doepfer_a100@yahoogroups.com, "vliesgaard" <vliesgaard@...>
using an a138c does not work in this regard, you have to use
a lowpass filter at the output. there is no other way.
best wishes
ingo
