Doepfer
Some suggestion for A-152
2006-10-05 by glabbeur
I don't have this module yet since I don't have my system but I have
a synth based on this ( Rotor EX by John Bowen -- on Creamware cards
 ) and I would like to know if you could make a fade knob +
modulation possibility on fade because it gives access to more smooth
enticing soundscapes in addition to hard switch ! ;-)
Re: Some suggestion for A-152
2006-10-06 by selfoscillate
this would be a totally different module.
the a152 is a switch and there are no transitions possible.
but the a135 + a144 combination should do the thing you want,
but only with four signals instead of eight, and only with
audio signals.
best wishes
ingo
2006-10-06 by glabbeur
Thanks Ingo, A-144 and A-135 are already ordered for that purpose
Whether it's the A-152 or A-144 to be modified but I would like to
see various waveform for morph / fade : A-152 does square, A-144
triangle, would be cool to have both in one module + sine, " rounded
squared " with CV for waveform.
Oh well, just an idea for a version 2 of the A-144 for instance !
"selfoscillate" <synaptic_music@...> wrote:
have
cards
smooth
> audio signals.
> best wishes
> ingo
AW: [Doepfer_a100] Re: Some suggestion for A-152
2006-10-09 by hardware@doepfer.de
If you use the A-161 (output 5 -> reset) in combination with the A-135 you
have the square solution. An A-129-3+4 can be used for voltage controlled
slew limiting of 4 CV signals. So I think there is no need for a new module.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von glabbeur
> Gesendet: Freitag, 6. Oktober 2006 19:18
> Betreff: [Doepfer_a100] Re: Some suggestion for A-152
> have
> cards
> smooth
> > audio signals.
> > best wishes
> > ingo
2006-10-09 by glabbeur
Thanks for the workarounds Dieter ! :-)
135 you
controlled
new module.
> Best wishes
> Dieter Doepfer
rounded
I
> > have
> > cards
> > smooth
> > > audio signals.
> > > best wishes
> > > ingo
> > Yahoo! Groups Links
