Doepfer
A-113 Subharmonic Generator digital?
2006-10-25 by jalmari3
Hello!
The A-113 manual says it has four times
• digital frequency divider (rectangle outputs) with
2-digit display and up/down buttons for divisor adjustment
• rectangle/sawtooth converter (with single output)
That "digital frequency divider" catched my eye. I suppose there are no
AD or DA converters present? No aliasing or "digitalness"?
Best regards
Jari Jokinen
AW: [Doepfer_a100] A-113 Subharmonic Generator digital?
2006-10-25 by hardware@doepfer.de
Right, no AD/DA. Only the frequency dividing is made digital (there's no
other way). The rectangle/sawtooth converter is pure analog.
If you need technical details: it's a voltage controlled current source that
is used to charge a capacitor (rising slope of the sawtooth). The fast
discharge (sawtooth reset) is triggered by the positive slope of the
internal rectangle. The control voltage for the current source is derived
from the rectangle by a simple frequency-to-voltage converter.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von jalmari3
> Gesendet: Mittwoch, 25. Oktober 2006 11:33
> Betreff: [Doepfer_a100] A-113 Subharmonic Generator digital?
> Hello!
> Best regards
> Jari Jokinen
