Doepfer
A-110 CV1 voltage question
2006-11-11 by igalben
hi,
I have a few questions to clarify the innerworking of the bus,
answers greatly appriciated.
assuming a-110 CV is still connected to the bus,
even though there is a A-190 connected to the same bus,
the a-110 will constantly be triggered by the bus
you can alter voltage properties by a-190 but still the bus will keep
it going. is this correct?
if you connect the cv1 of A-110 to another source, it will tap into
that source, but if the source stops, it will tap back into the bus
(even if there is a cable inserted into the cv1)?
is this correct?
and last but not least, is there a way to control the bus, thus the cv
is only triggered by A-190. not an infinite trigger. or does the cv
connection to the bus needs to be chopped off)??? /$$*?
thanks again.
--i
