Doepfer
BBD 1024 and 2048
BBD 1024 and 2048
2006-11-12 by bellenger_a
I've ordered 2048 stages BBD modules... but after more accurate reading I got a little
confused...
in the audio examples in the Doepfer site... 2048 is used for Karplus appplication, but in
the pdf file for using the BBD module... it says that 1024 is recommended for Karplus
applications...
DOES THIS REALLY MATTER?
bye
Alexandre
Re: BBD 1024 and 2048
2006-11-13 by selfoscillate
hello alexandre,
a 2048 stages bbd can also be used for karplus-strong-synthesis,
but a 1024 stages bbd is better for that task.
with a 2048 stages bbd you cannot play high pitched notes.
the shorter the bbd the higher the notes you can play.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "bellenger_a" <bellenger_a@...>
> confused...
> applications...
> bye
> Alexandre
