RE: [Doepfer_a100] Re: 8 channel cv mixer
2006-11-13 by David Salter
Thanks Dieter That's very interesting Rgds David David Salter Senior Consultant PSG Reuters Messaging: david.salter.reuters.com@reuters.net (t) +44 (0)20 7542 2402 | (m) 07990562402 | (f) 52699 Get the latest news at Reuters.com
-----Original Message----- From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of hardware@doepfer.de Sent: 13 November 2006 16:02 To: Doepfer_a100@yahoogroups.com Subject: AW: [Doepfer_a100] Re: 8 channel cv mixer > Dieter, > > that would be interesting as it would save me daisy chaining mixers > and loosing an i/p > > david > > David Salter > Senior Consultant > PSG David, the mod is simple: For the old version of A-138a/b remove the dual opamp IC1 (TL062) of one of the two modules and connect pin #2 of IC1 (i.e. the inverting input pin of the first opamp) of both modules. The module with the missing IC1 has no longer a output signal available. If you want to have a output of this module connect pin #7 of IC1 (i.e. output of the second opamp) of both modules. Now you have two outputs with adjustable levels available. For the new version of A-138a/b its similar but here a quad opamp (TL064) is used. Remove the quad opamp IC1 (TL064) of one of the two modules and connect pin #9 of IC1 (i.e. the inverting input pin of the first opamp) of both modules. The module with the missing IC1 has no longer a output signal available. If you want to have a output connect the output sockets of both modules. In this case the output of the second module cannot be adjusted (different circuit compared to the old version). But you may connect the pin header JP2 of the first module to the output of the second module. Then you have the inverted output available. For the polarizing mixer A-138c remove IC3 (TL062) of one of the two modules and connect pin #6 of IC3 (i.e. the inverting input pin of the mixing opamp) of both modules. The module with the missing IC3 has no longer a output signal available. If you want to have a output of this module connect pin #1 of IC3 (i.e. output of the final opamp) of both modules. In this case the level is the same for both outputs. The master control of the second module has no function. We already discussed a simple "mixing expander" module that could be used to add 5 more inputs to A-138a/b. It will be about 20-30% cheaper than an A-138a/b as no integrated circuits and no power supply are necessary for such a simple module (only a front panel with five sockets, five potentiometers+knobs and five resistors). How about a poll ? Good luck, Dieter Doepfer Yahoo! Groups Links This email was sent to you by Reuters, the global news and information company. To find out more about Reuters visit www.about.reuters.com Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Reuters Ltd.
