Doepfer
message from Dieter regarding the crossfader module
2006-11-24 by Bakis Sirros
Dieter says:
"Dear members,
I designed a crossfader module based on Florian's
suggestions. Here is the
link for the preliminary info:
www.doepfer.de/a138d.htm
It is only a preliminary version and should be treated
as as basis for
discussions. From my point of view there are three
possible ways:
1. A complete module similar to the suggested A-138d
2. An expansion module that has to be connected to an
existing A-138 (a or
b). This would be a little bit cheaper as the
electronics of the A-138 can
be used (but not much as the electromechanical parts
remain the same and the
electronics is not very expensive). For this solution
the single outputs
would not be available and a little bit of soldering
is necessary (2 wires
have to be soldered to the A-138). I don't think that
this solution is
meaningful.
3. same as 2. but only as a DIY project. It's very
simple. Most of the work
will be the front panel processing. The "electronics"
is only a few
resistors some potentiometers. I can publish the
schematics on the A-100 DIY
page.
Bakis, maybe a poll will be helpful (thank you in
advance ... :-). And of
course ideas/improvements of the suggested A-138d.
Best wishes
Dieter Doepfer"
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
Re: [Doepfer_a100] message from Dieter regarding the crossfader module
2006-11-24 by Florian Anwander
Hi folks,
> is only a few
> page.
This is a trap ;-) Mechanical front panel processing is the ugliest job
while doing a diy module. I think, every synth-diyer, who is able to do
good frontpanel processing and is able to solder, will be able to create
the simple schematic for a crossfader on his own.
Florian
