Doepfer
Poll results for Doepfer_a100
2006-12-16 by Doepfer_a100@yahoogroups.com
The following Doepfer_a100 poll is now closed.  Here are the
final results:
POLL QUESTION: How would you like the forthcoming A138d crossfader module to be realized? [for a suggested module sketch look here:
http://www.doepfer.de/a138d.htm ] regarding your options to choose from: 1. A complete module similar to the suggested A-138d
2. An expansion module that has to be connected to an existing A-138 (a or
b). This would be a little bit cheaper as the electronics of the A-138 can
be used (but not much as the electromechanical parts remain the same and the
electronics is not very expensive). For this solution the single outputs
would not be available and a little bit of soldering is necessary (2 wires
have to be soldered to the A-138). I don't think that this solution is
meaningful.
3. same as 2. but only as a DIY project. It's very simple. Most of the work
will be the front panel processing. The "electronics" is only a few
resistors some potentiometers. I can publish the schematics on the A-100 DIY
page.
CHOICES AND RESULTS
- option 1., 14 votes, 82.35%
- option 2., 0 votes, 0.00%
- option 3., 3 votes, 17.65%
For more information about this group, please visit
http://groups.yahoo.com/group/Doepfer_a100
For help with Yahoo! Groups, please visit
http://help.yahoo.com/help/us/groups/
AW: [Doepfer_a100] Poll results for Doepfer_a100
2006-12-16 by hardware@doepfer.de
Thank you again for the poll. And again I assumed something like that ...
We already have a prototype A-138d available. It can be seen at the NAMM
booth of Analogue Haven in January 2007, as well as the tapped BBD module
A-188-2 (regular modules) and the prototypes of the universal AD/DA module
with two available modes (clocked delay and bit cruncher), the dynamic VCO
A-111-2, the voltage controlled quadrature LFO A-143-9, the LCD scope module
A-197-2 and probably even the mix expander A-138x (without front panel
printing).
Best wishes
Dieter Doepfer
